gcoupe
(Geoff Coupe)
April 4, 2021, 8:45am
1
I’ve recently moved to the Z-Wave JS to MQTT so that I can use its Z-Wave control panel with Z-Wave JS.
I’ve noticed that I’m now getting Ingress errors showing up in the log of the form:
21-04-04 08:07:42 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.0:8099/socket.io/?EIO=4&transport=websocket&sid=y0gfQ6UWAgrZxPCBAAA4')
21-04-04 08:34:07 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.0:8099/socket.io/?EIO=4&transport=websocket&sid=5QT93fX3AXdMyt0QAAA6')
21-04-04 08:34:08 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.0:8099/socket.io/?EIO=4&transport=websocket&sid=-n1GGeF9YD4b8cCXAAA8')
These usually result in the Z-Wave web interface not loading properly. Is that the only thing, or should I be more worried about these errors? Thanks.
System Health
version
core-2021.3.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
virtualenv
false
python_version
3.8.7
os_name
Linux
os_version
5.4.83-v8
arch
aarch64
timezone
Europe/Amsterdam
Home Assistant Community Store
GitHub API
ok
Github API Calls Remaining
4933
Installed Version
1.11.3
Stage
running
Available Repositories
841
Installed Repositories
11
Home Assistant Cloud
logged_in
true
subscription_expiration
19 April 2021, 2:00
relayer_connected
true
remote_enabled
false
remote_connected
false
alexa_enabled
true
google_enabled
true
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Home Assistant Supervisor
host_os
Home Assistant OS 5.12
update_channel
stable
supervisor_version
supervisor-2021.03.6
docker_version
19.03.13
disk_total
109.3 GB
disk_used
9.1 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
File editor (5.2.0), Samba share (9.3.1), InfluxDB (4.0.3), Terminal & SSH (9.1.0), Grafana (6.2.0), Z-Wave JS (0.1.16), Z-Wave JS to MQTT (0.9.1)
Lovelace
dashboards
2
resources
8
views
4
mode
storage
I have the same problem.
Following this topic
paszczak
(Jakub)
April 8, 2021, 9:59am
3
Same here
21-04-08 08:48:17 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.0:8099/socket.io/?EIO=4&transport=websocket&sid=SgYsgootyWWNs2ORAAAa')
21-04-08 08:48:46 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.0:8099/socket.io/?EIO=4&transport=websocket&sid=0Cgl31cy-sPAgnzeAAAc')
but it doesn’t seem’s to affect anything…
Same here, watching this as well.
I’m also encountering this when using “Heal” on a dead node.
zwavejs2mqtt: 4.0.0
zwave-js: 7.3.0
Watching issue, I’ll post more info whenever I have time for this (as I’ve replaced all my valves today, and have a few more to go, that might be later this week)
I’m seeing this as well. Has anyone found a fix? Or what the cause really is?
djalexnl
(Alexander de Boer)
August 21, 2021, 9:03pm
11
Same issue Here after changing Zwave.js to mqtt
Happends when opening the Gui interface
lucode
(Lucas)
November 23, 2021, 4:52pm
13
same here:
Did anybody report this issue on Github?
zwavejs2mqtt: 5.8.0
zwave-js: 8.4.1
