After recent 2025.4.1 upgrade Met Office integration no longer working
I am getting “entity not available” and also when I go to the login page my username and password is no longer valid. It also shows a met office premium page.
Have they changed the free tiers?
Is this in issue with the integration?
Which Met Office service are you using?
The old one, Datapoint, is being phased out and replaced by Datahub. You need a different account.
I don’t think the HA integration works with Datahub yet. However there is an excellent set of templates and sensors to access the new API here:
Pretty sure I have registered for Datahub and that is what I was using to get data via the API key
I made no changes and it seems to all be working again now.,…
For me the service has been dropping in and out since the start of April.
The Met Office Datapoint service is ending in September this year and is currently unsupported.
If you’re using the “official” HA integration, Datapoint is the service you are accessing, and you need to migrate soon.
I am using the official integration it seems.
Same for me. Looks like I need to migrate.
I migrated and installed the other version. It works fine you just need to update with the new entity names. There is no three hourly, its hourly now.
What version did you install? I may be being dopey here, but I can only get the official integration working with my old datapoint api key.
This is the current one I have installed: Met Office - Home Assistant
But i did need to create a new account on the datahub not datapoint server.
I’m a home assistant newbie and I’ve been trying to integrate the Met Office into my home assistant. I followed the link in this post to get the relevant integration into home Assistant I set up a Met Office Data Hub account and got an API I’ve waited a couple of days to make sure that everything should settle down but it just says invalid authentication. I’d appreciate any guidance that someone may be able to offer And can I just confirm that the API key is over 1600 characters long?
Many thanks.
I’m finding Home Assistant a bit of a challenge but its rewards are great!
use Global Spot
  1. After registration, subscribe to Site Specific Global Spot dataset to obtain your API key. Free tier subscription gives 360 calls per day, which is enough for using this integration
Their API has been significantly downgraded, IMHO. I only used their text forecast for my location under free tier for few calls a day only. Right now, there is no such thing. And even if I wanted to use a site-specific model, they charge extortionate amounts for what it is. Having local weather station from Ecowitt I don’t really need anything except just a quick text forecast summary for today, tonight, and maybe for the week ahead. This is absolutely useless now…
Does anyone know any alternatives (text summary) for something like what they were offering up to now?
