after the installation of 2026.9.x (1 or 2) the integration Fibaro doesn’t work all the modules previously added are setted as unavailable
the previous release 2026.8.3 was ok and all the module Up
sounds related to 2026.9.2 update breaks zha + zwave_js integrations
seems the problem isn’t only with fibaro integration
i find the problem, sometime ago i had installed fibaro component as a custom_component (i don’t remember why, but it was surely for a reason), but as the fibaro plugin is distributed in the core, there is no reminder for updates (rather than the changelog).
therefore the update of the code isn’t setted and the new HA release 2026.9.x have some deprecated code like device_id which become incompatible now.
the solution is :
- remove the code in custom_component
- restart HA
- try to add a new hub via fibaro integration (the official one) - which reinstall or point to the right code
- it’s said that the hub is already registered
==> everything become OK
