My sanity saved, thank you! I tried changing the IP address but it reverted on restarting.
I migrated from a Rpi3 to a Lenovo M600 (VirtualBox), and this was the only real issue I had.
Hey,
I have what I believe is the same issue. Last night I turned off my Home Assistant box for around an hour. After turning it back on my Aqara sensors are failing to update. Within the core_deconz UI they note a last refreshed time of moments before I turned off my Home Assistant box (over 24 hours ago)
I’ve read through the fixes above, both changing the IP and changing the host to “core-deconz”. However, neither appear to be working for me. I fear I might be doing something wrong.
The file I am editing is:
“/config/.storage/core.config_entries”
And the section within that file looks something like this:
"entry_id": "REDACTED",
"version": 1,
"domain": "deconz",
"title": "REDACTED",
"data": {
"host": "172.30.33.0",
"port": 40850,
"api_key": "REDACTED"
"options": {
"master": true
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"unique_id": null,
"disabled_by": null
After changing the line:
“host”: “172.30.33.0”,
And restarting the box. I get the same results, the devices do NOT connect and it also appears that the IP within the Phoscon view still reads:
Phoscon-GW 172.30.33.0
Any clues what I could be doing wrong?
To add to the above, here is an example of the current state of one of my sensors:
As you can see, it’s not been refreshed for two days now (since the moment I took the Home Assistant box offline for an hour). This is also the case for my other sensors.
