Hi all,
I have homeassistant on a vm in a qnap nas.
After updating homeassistant (core and operating system) to 2023.11.0 all my integrations won’t start.
also the aeotec zwave gen. 5 is not loading anymore.
How can I resolve this?
Regards
Hi all,
Regards
A good start would be to review errors in your logs.
I had this same issue using HA container and a stand alone container of zwavejsui. A second restart of the HA container fixed the first issue and all of my integrations loaded. For the zwave gen 5 not loading, I was finally forced to do the firmware update on my gen 5 stick as whenever the driver initialized, it would communicate briefly then reset and the stick would be off and unresponsive. I had to unplug it for a few seconds and plug it back in to get it to be recognized. The fox for that was either turn off the soft reset of the controller in the zwave js ui settings or do the firmware update on the stick. I did the latter and haven’t had any problems since. Anyway, that’s just my experience. You should read the logs and then search the forums or GitHub issues for the errors and warnings you are seeing.
Hi all,
Thanks for the answers.
One of the problems is the supervisor. In the logfile I find this:
Can you tell me how to tackle it? I have allready restored a backup, but it does not solve the problem.
Thanks.
Logger: homeassistant.config_entries
Source: config_entries.py:399
First occurred: 10:58:51 (1 occurrences)
Last logged: 10:58:51
Error setting up entry Supervisor for hassio
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 399, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 673, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 1390, in async_forward_entry_setups
await asyncio.gather(
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 1411, in async_forward_entry_setup
result = await async_setup_component(self.hass, domain, self._hass_config)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 102, in async_setup_component
return await task
File “/usr/src/homeassistant/homeassistant/setup.py”, line 220, in _async_setup_component
processed_config = await conf_util.async_process_component_config(
File “/usr/src/homeassistant/homeassistant/config.py”, line 913, in async_process_component_config
p_integration = await async_get_integration_with_requirements(hass, p_name)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 52, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 171, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 186, in _async_process_integration
await self.async_process_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 247, in async_process_requirements
async with self.pip_lock:
File “/usr/local/lib/python3.11/asyncio/locks.py”, line 15, in aenter
await self.acquire()
File “/usr/local/lib/python3.11/asyncio/locks.py”, line 114, in acquire
await fut
asyncio.exceptions.CancelledError: Global task timeout
