Switch.turn_on action for zwave switch fails if within an automation after Zwave JS UI 4.0 installed. No problems with 3.24 version. Here is message:
Error while executing automation automation.garage_light_on_when_door_opens: Unable to set value 48-37-0-targetValue: zwave_error: Z-Wave error 202 - Failed to send the message after 3 attempts (ZW0202)
v4.0.1 did not have any relevant fix for this problem (not even sure why it was released). You’ll have to wait for a potential v4.0.2 that includes driver v15.0.3.
Well, re-interviewing did not make a difference. Still saw errors coming in. Downgraded to 3.24.0. Going to keep an eye out if this is the fix for now.
Yeah, seems that this is also the reason of my problem - I have few sirens which act as switches (and the switch is the only control they have, and in automation I have literally no actions available for these devices:
Strange. I do all my automations using yaml manually.
In my case the automation uses the same script for turning on and off a switch. That works most of the time. Except for when more scripts should be executed at the same time.
Before I go for downgrading to version 3.x, I’ll check if using group (I have my sirens grouped) works, or if using action instead of device works in that case.
Edit: groups still works, switching devices from the dashboard as well, only atomations have this broken. But only for certain devices, not all of them
It didn’t solve my issue, still can’t select any actions for some devices.
However, they work from dashboard, and i.e when calling an action on group which includes them.
Maybe it is a bug in automation themselves?
Strange
