(again...) 500 Internal Server Error Server got itself in trouble
Dear all,
yes, 500 Internal Server Error Server got itself in trouble, again.
There are dozens or hundreds of threads related to this issue.
I’ve read many of these but haven’t found any good solutions. Maybe it depends on my environment…
DS216j (pretty old but it works)
DSM 7.1.1-42962 Update 4
HA Core 2022.10.5.-19 recently updated
Before this update I had no problems integrating devices connected to my network and creating automations: Shelly, Netatmo.
Since I installed this version, at first the Shelly devices were not recognized then, after doing a new installation, not even the Netatmo device is recognized (500 Internal Server Error Server…)
An indication: in my opinion devices or services that are NOT on my home network (shelly…etc.) are instead integrated without problems, for example: Tuya, Accuweather, etc.
It appears that the HA server is unable to reach devices on the home network.
Used several browsers but nothing changes.
The error is still the same: 500 Internal Server Error Server got itself in trouble.
Thanks for your precious support
Logger: homeassistant.util.package
Source: util/package.py:98
First occurred: 16:46:19 (6 occurrences)
Last logged: 17:11:50
Unable to install package aioshelly==2.0.2: WARNING: Missing build requirements in pyproject.toml for multidict<7.0,>=4.5 from https://files.pythonhosted.org/packages/4a/15/bd620f7a6eb9aa5112c4ef93e7031bcd071e0611763d8e17706ef8ba65e0/multidict-6.0.4.tar.gz (from aiohttp->aioshelly==2.0.2). WARNING: The project does not specify a build backend, and pip cannot fall back to setuptools without ‘wheel’. error: subprocess-exited-with-error × Building wheel for multidict (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [62 lines of output] ********************* * Accelerated build * ********************* running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-cpython-310 creating build/lib.linux-armv7l-cpython-310/multidict copying multidict/init.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_multidict_py.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_abc.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_compat.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_multidict_base.py → build/lib.linux-armv7l-cpython-310/multidict running egg_info writing multidict.egg-info/PKG-INFO writing dependency_links to multidict.egg-info/dependency_links.txt writing top-level names to multidict.egg-info/top_level.txt reading manifest file ‘multidict.egg-info/SOURCES.txt’ reading manifest template ‘MANIFEST.in’ warning: no previously-included files matching ‘.pyc’ found anywhere in distribution warning: no previously-included files found matching ‘multidict/_multidict.html’ warning: no previously-included files found matching 'multidict/.so’ warning: no previously-included files found matching ‘multidict/.pyd’ warning: no previously-included files found matching 'multidict/.pyd’ no previously-included directories found matching ‘docs/_build’ adding license file ‘LICENSE’ writing manifest file ‘multidict.egg-info/SOURCES.txt’ /var/packages/python310/target/lib/python3.10/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning: Installing ‘multidict._multilib’ as data is deprecated, please list it in packages. !! ############################ # Package would be ignored # ############################ Python recognizes ‘multidict._multilib’ as an importable package, but it is not listed in the packages configuration of setuptools. ‘multidict._multilib’ has been automatically added to the distribution only because it may contain data files, but this behavior is likely to change in future versions of setuptools (and therefore is considered deprecated). Please make sure that ‘multidict._multilib’ is included as a package by using the packages configuration field or the proper discovery methods (for example by using find_namespace_packages(...)/find_namespace: instead of find_packages(...)/find:). You can read more about “package discovery” and “data files” on setuptools documentation page. !! check.warn(importable) copying multidict/init.pyi → build/lib.linux-armv7l-cpython-310/multidict copying multidict/py.typed → build/lib.linux-armv7l-cpython-310/multidict running build_ext building ‘multidict._multidict’ extension creating build/temp.linux-armv7l-cpython-310 creating build/temp.linux-armv7l-cpython-310/multidict /github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -I/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/arm-unknown-linux-gnueabi/sysroot/usr/include -D__ARM_PCS_VFP=1 -I/github/workspace/spk/python310/work-armv7-7.1/install//var/packages/python310/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/lib -I /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/include -I/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/arm-unknown-linux-gnueabi/sysroot/usr/include -D__ARM_PCS_VFP=1 -I/github/workspace/spk/python310/work-armv7-7.1/install//var/packages/python310/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/lib -I /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/include -fPIC -I/volume1/@appstore/homeassistant/env/include -I/var/packages/python310/target/include/python3.10 -c multidict/_multidict.c -o build/temp.linux-armv7l-cpython-310/multidict/_multidict.o -O2 -std=c99 -Wall -Wsign-compare -Wconversion -fno-strict-aliasing -pedantic error: command ‘/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc’ failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for multidict ERROR: Could not build wheels for multidict, which is required to install pyproject.toml-based projects [notice] A new release of pip available: 22.2.2 → 23.0.1 [notice] To update, run: pip install --upgrade pip
Unable to install package pyatmo==7.1.1: WARNING: Missing build requirements in pyproject.toml for multidict<7.0,>=4.5 from https://files.pythonhosted.org/packages/4a/15/bd620f7a6eb9aa5112c4ef93e7031bcd071e0611763d8e17706ef8ba65e0/multidict-6.0.4.tar.gz (from aiohttp<4.0.0,>=3.7.4->pyatmo==7.1.1). WARNING: The project does not specify a build backend, and pip cannot fall back to setuptools without ‘wheel’. error: subprocess-exited-with-error × Building wheel for multidict (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [62 lines of output] ********************* * Accelerated build * ********************* running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-cpython-310 creating build/lib.linux-armv7l-cpython-310/multidict copying multidict/init.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_multidict_py.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_abc.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_compat.py → build/lib.linux-armv7l-cpython-310/multidict copying multidict/_multidict_base.py → build/lib.linux-armv7l-cpython-310/multidict running egg_info writing multidict.egg-info/PKG-INFO writing dependency_links to multidict.egg-info/dependency_links.txt writing top-level names to multidict.egg-info/top_level.txt reading manifest file ‘multidict.egg-info/SOURCES.txt’ reading manifest template ‘MANIFEST.in’ warning: no previously-included files matching ‘.pyc’ found anywhere in distribution warning: no previously-included files found matching ‘multidict/_multidict.html’ warning: no previously-included files found matching 'multidict/.so’ warning: no previously-included files found matching ‘multidict/.pyd’ warning: no previously-included files found matching 'multidict/.pyd’ no previously-included directories found matching ‘docs/_build’ adding license file ‘LICENSE’ writing manifest file ‘multidict.egg-info/SOURCES.txt’ /var/packages/python310/target/lib/python3.10/site-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning: Installing ‘multidict._multilib’ as data is deprecated, please list it in packages. !! ############################ # Package would be ignored # ############################ Python recognizes ‘multidict._multilib’ as an importable package, but it is not listed in the packages configuration of setuptools. ‘multidict._multilib’ has been automatically added to the distribution only because it may contain data files, but this behavior is likely to change in future versions of setuptools (and therefore is considered deprecated). Please make sure that ‘multidict._multilib’ is included as a package by using the packages configuration field or the proper discovery methods (for example by using find_namespace_packages(...)/find_namespace: instead of find_packages(...)/find:). You can read more about “package discovery” and “data files” on setuptools documentation page. !! check.warn(importable) copying multidict/init.pyi → build/lib.linux-armv7l-cpython-310/multidict copying multidict/py.typed → build/lib.linux-armv7l-cpython-310/multidict running build_ext building ‘multidict._multidict’ extension creating build/temp.linux-armv7l-cpython-310 creating build/temp.linux-armv7l-cpython-310/multidict /github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -I/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/arm-unknown-linux-gnueabi/sysroot/usr/include -D__ARM_PCS_VFP=1 -I/github/workspace/spk/python310/work-armv7-7.1/install//var/packages/python310/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/lib -I /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/include -I/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/arm-unknown-linux-gnueabi/sysroot/usr/include -D__ARM_PCS_VFP=1 -I/github/workspace/spk/python310/work-armv7-7.1/install//var/packages/python310/target/include -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -L /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/lib -I /github/workspace/spk/python310/work-armv7-7.1/install/var/packages/python310/target/include -fPIC -I/volume1/@appstore/homeassistant/env/include -I/var/packages/python310/target/include/python3.10 -c multidict/_multidict.c -o build/temp.linux-armv7l-cpython-310/multidict/_multidict.o -O2 -std=c99 -Wall -Wsign-compare -Wconversion -fno-strict-aliasing -pedantic error: command ‘/github/workspace/toolchain/syno-armv7-7.1/work/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-gcc’ failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for multidict ERROR: Could not build wheels for multidict, which is required to install pyproject.toml-based projects [notice] A new release of pip available: 22.2.2 → 23.0.1 [notice] To update, run: pip install --upgrade pip
