AI Assistant That Patrols, Inspects, Repairs, and Learns
Most AI integrations for Home Assistant solve one problem: how to let AI control devices — turn on lights, adjust the AC, check temperatures, call services. Useful, sure, but ultimately still a smarter remote control.
This is not another OpenAI Conversation replacement.
Claw Assistant tackles a different problem:
Can AI step inside Home Assistant and work like a system operator — handling troubleshooting, maintenance, orchestration, and long-running tasks?
The longer you use Home Assistant, the more it resembles a growing household system: more devices, more automations, messier dashboards, and the occasional breakdown. What you need is an AI maintenance assistant that looks after the system itself.
Managing the Entire HA
A typical AI conversation integration stops here:
User speaks → AI picks a tool → calls one service → returns a result
Claw Assistant treats every message as a task, not a command. Once a task starts, it can continuously read system state, invoke tools, check results, and proceed to the next step. If the answer is incomplete, it keeps going; if a tool fails, it tries another path; if the model falls short, it switches to a backup agent; if it needs your confirmation, it pauses and explains why.
Scenarios it handles:
  • Automation troubleshooting: Why didn't this automation fire last night?
  • System inspection: Which entities have been unavailable for a long time?
  • Long-term watch duty: Check doors, lights, AC, and the vacuum every night
  • Visual judgment: Is there a package at the front door? Check the camera and notify me
  • Dashboard cleanup: Reorganize the Lovelace page for a specific area
  • Config maintenance: Review logs, diagnose integrations, stage config changes
  • Model failover: When the primary model fails, switch to a local model and keep going
  • Experience retention: Learn from a failure and avoid the same mistake next time
Built-in capabilities:
  • Device control: Service calls, batch control, state queries, area device discovery
  • Automations / Scripts: Create, read, update, delete, trigger, enable/disable
  • System maintenance: Logs, diagnostics, integration reload, HACS management, staged config edits
  • Registry management: Areas, floors, labels, categories, entity registry
  • Helper management: Create input_boolean, input_text, timer, counter, template sensor, and other native helpers
  • Dashboard management: Create and edit Lovelace views and cards with atomic patch support
  • Visual understanding: Camera snapshots, image / GIF / video analysis
  • Web search: Built-in Baidu / Bing search and page content fetching, no extra search API needed
  • Long-term memory: MemoryGraph, ConversationMemory, Workspace documents
  • Skill system: Markdown-based skills, installable, readable, deletable
  • Self-evolution: Post-task review that proposes Skill / Guide / Memory changes, applied only after human approval
  • Self-governance: Periodic cleanup of duplicate, outdated, or conflicting skills
  • Multi-agent failover: Automatic switch to backup agents when the primary fails
  • Dynamic AI entities: Create sensor, binary_sensor, switch, button — turn AI judgments and task states into HA entities
Each capability alone is just a tool. Combined, AI can do system-level work inside HA: read logs, check history, compare states, fix automations, reorganize dashboards, create long-term inspections, generate diagnostic entities, remember past pitfalls, and take a shorter path next time.
Real Watch Duty: Not Reminders — Continuous Monitoring
Many assistants call their long-running features "reminders." That is all they are.
Claw Assistant has a full watch-duty task system. You can say:
"Every night at 10 PM, check doors, AC, lights, and the vacuum. Notify me if anything is off."
It creates a background Heartbeat task, executed on a cron or interval schedule. After each run it records state; one-time tasks can auto-delete on success, or persist as long-term inspections.
Heartbeat can push results back to the conversation source, and can send camera snapshots, voice, video, and GIF media.
Dashboard Maintenance: Careful Edits, Like a Human
Many AI tools write Lovelace the rough way: read some config, rewrite the whole thing.
Claw Assistant's Dashboard tool follows a patch-first rule. When modifying existing cards, it prefers anchored, small-scope, atomic patches; it can dry-run and preview diffs; full rewrites only happen when more than half the card changes.
Your dashboard took a lot of time to tune. AI should not rewrite an entire card just to add one sensor.
Minimum Tokens
Simple things stay off the LLM. Complex things take fewer wrong turns.
Clear commands like turning on lights or checking temperature continue through HA's native local intent path — zero tokens, faster, more stable. The agent loop only activates when a request requires judgment, troubleshooting, creation, or verification.
Inside the loop: task management, continuation judgment, budget caps, context compression, and response cleanup. When a long conversation exceeds the threshold, context is compressed before continuing. The LLM is used only where reasoning is truly needed.
Skills, Guides, and Memory: Growing With Your Home
Claw Assistant has its own Workspace, Skills, Home Assistant Guide, and MemoryGraph — a four-layer structure:
  • Workspace: Defines who it is, how it speaks, your household habits, and how tools should be used
  • Skills: Installable procedures — nightly inspection, energy analysis, daily home report, HACS troubleshooting
  • Home Assistant Guide: Built-in HA operations manual, consulted for troubleshooting, dashboards, integrations, backups, ESPHome, and more
  • MemoryGraph: Records long-term facts, decisions, repair experiences, and their relationships
You can have it install a "Nightly Inspection Skill" to check doors, lights, AC, and the vacuum every night before bed. Or a "HA Troubleshooting Skill" that follows a fixed procedure when automations fail, entities become unavailable, or integrations act up. It can also remember household preferences: no disturbances at night, be more careful with nursery notifications, certain devices often give false alarms.
After a task completes, the system can review the execution. If an experience is worth keeping, it proposes changes to Skills / Guides / Memory. If skills are piling up, duplicated, or outdated, it can propose cleanup.
All self-evolution requires human approval.
It grows, but control stays in your hands.
Why a HA Integration
Claw Assistant needs access to HA's own working environment: voice Assist, dashboards, automation triggers, entity states, history, HACS, registries, config files, system logs, cameras, notifications, and IM push. All of these already live inside HA.
Placing the agent inside HA means direct access to HA state, direct use of HA tools, and direct scheduling of long-term tasks within HA. No extra bridge, no extra container.
Install via HACS. Remove anytime.
Bringing HA's AI experience to the "install and use" level of modern agent tools, instead of staying at "configure 20 function specs first."
Repository
Claw Assistant: https://github.com/ha-china/ha_claw
Optional model configuration companion: GitHub - ha-china/ai_hub: This home assistant integration is a completely free AI service, an integration built from various free resources available on the Internet, allowing users to experience more possibilities. · GitHub
ai_hub handles model configuration. Claw Assistant turns those models into household agents inside HA.
An AI assistant that can patrol, inspect, repair, and learn is an advanced system designed to handle tasks with minimal human involvement. It uses technologies like machine learning, computer vision, sensors, and automation to monitor environments, detect problems, and take action when needed. These assistants are commonly used in industries such as manufacturing, healthcare, security, and logistics to improve efficiency and reduce manual workload.
How it works:
  • Patrols: Continuously monitors spaces, equipment, or systems to identify unusual activity or risks.
  • Inspects: Uses cameras, sensors, and data analysis to detect faults, damage, or performance issues.
  • Repairs: In some cases, it can trigger automated fixes or support maintenance teams with accurate repair suggestions.
  • Learns: Improves over time by analyzing past actions, outcomes, and new data patterns.
Businesses are increasingly adopting custom AI integration services to build AI assistants that match their specific operational needs. These solutions help create smarter systems that can adapt, make informed decisions, and support long-term business growth without relying heavily on manual processes.
