Hello all!
I have gotten the camera working with HA but as soon as I try to configure servo I get only “[esp32_camera:162]: Got invalid frame from camera!”
I am following https://siytek.com/esphome-servo-example/ with changes to esp32 from ESP32 LEDC Output — ESPHome .
I have tried other pins other than GPIO2 and it is all the same. As far as I can tell there is no mention of these tf card pins being used for anything in esp32_camera.cpp so they should be free to use. Someone with better understanding on how this works got any ideas?
default_yaml:
esphome:
esp32:
board: esp32cam
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "***"
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
ota:
password: "***"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Default Fallback Hotspot"
password: "**"
captive_portal:
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 1280x1024
jpeg_quality: 10
# ... Frame Settings
# Flashlight
output:
- platform: gpio
pin: GPIO4
- platform: ledc
pin: GPIO2
frequency: 50 Hz
light:
- platform: binary
output: gpio_4
servo:
- id: my_servo
output: pwm_output
log output:
INFO Reading configuration /config/esphome/default.yaml...
WARNING GPIO0 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO4 is a Strapping PIN and should be avoided.
WARNING GPIO2 is a Strapping PIN and should be avoided.
INFO Starting log output from default.local using esphome API
WARNING Can't connect to ESPHome API for default.local: Error resolving IP address: [Errno -5] No address associated with hostname
INFO Trying to reconnect to default.local in the background
INFO Successfully connected to default.local
[12:13:40][I][app:102]: ESPHome version 2022.8.3 compiled on Sep 28 2022, 09:50:05
[12:13:40][C][wifi:491]: WiFi:
[12:13:40][C][wifi:353]: Local MAC: 0C:DC:7E:61:55:98
[12:13:40][C][wifi:354]: SSID: [redacted]
[12:13:40][C][wifi:355]: IP Address: 192.168.1.156
[12:13:40][C][wifi:357]: BSSID: [redacted]
[12:13:40][C][wifi:358]: Hostname: 'default'
[12:13:40][C][wifi:360]: Signal strength: -38 dB ▂▄▆█
[12:13:40][C][wifi:364]: Channel: 1
[12:13:40][C][wifi:365]: Subnet: 255.255.255.0
[12:13:40][C][wifi:366]: Gateway: 192.168.1.1
[12:13:40][C][wifi:367]: DNS1: 192.168.1.168
[12:13:40][C][wifi:368]: DNS2: 0.0.0.0
[12:13:40][C][logger:275]: Logger:
[12:13:40][C][logger:276]: Level: DEBUG
[12:13:40][C][logger:277]: Log Baud Rate: 115200
[12:13:40][C][logger:278]: Hardware UART: UART0
[12:13:40][C][gpio.output:010]: GPIO Binary Output:
[12:13:40][C][gpio.output:011]: Pin: GPIO4
[12:13:40][C][ledc.output:118]: LEDC Output:
[12:13:40][C][ledc.output:119]: Pin GPIO12
[12:13:40][C][ledc.output:120]: LEDC Channel: 0
[12:13:40][C][ledc.output:121]: Frequency: 50.0 Hz
[12:13:40][C][light:104]: Light '$hostname light'
[12:13:40][C][esp32_camera:048]: ESP32 Camera:
[12:13:40][C][esp32_camera:049]: Name: bedroom
[12:13:40][C][esp32_camera:050]: Internal: NO
[12:13:40][C][esp32_camera:052]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[12:13:40][C][esp32_camera:053]: VSYNC Pin: 25
[12:13:40][C][esp32_camera:054]: HREF Pin: 23
[12:13:40][C][esp32_camera:055]: Pixel Clock Pin: 22
[12:13:40][C][esp32_camera:056]: External Clock: Pin:0 Frequency:20000000
[12:13:40][C][esp32_camera:057]: I2C Pins: SDA:26 SCL:27
[12:13:40][C][esp32_camera:058]: Reset Pin: -1
[12:13:40][C][esp32_camera:085]: Resolution: 1280x1024 (SXGA)
[12:13:40][C][esp32_camera:101]: JPEG Quality: 10
[12:13:40][C][esp32_camera:103]: Contrast: 0
[12:13:40][C][esp32_camera:104]: Brightness: 0
[12:13:40][C][esp32_camera:105]: Saturation: 0
[12:13:40][C][esp32_camera:106]: Vertical Flip: ON
[12:13:40][C][esp32_camera:107]: Horizontal Mirror: ON
[12:13:41][C][esp32_camera:108]: Special Effect: 0
[12:13:41][C][esp32_camera:109]: White Balance Mode: 0
[12:13:41][C][esp32_camera:112]: Auto Exposure Control: 1
[12:13:41][C][esp32_camera:113]: Auto Exposure Control 2: 0
[12:13:41][C][esp32_camera:114]: Auto Exposure Level: 0
[12:13:41][C][esp32_camera:115]: Auto Exposure Value: 300
[12:13:41][C][esp32_camera:116]: AGC: 1
[12:13:41][C][esp32_camera:117]: AGC Gain: 0
[12:13:41][C][esp32_camera:118]: Gain Ceiling: 0
[12:13:41][C][esp32_camera:124]: Test Pattern: NO
[12:13:41][C][servo:013]: Servo:
[12:13:41][C][servo:014]: Idle Level: 7.5%
[12:13:41][C][servo:015]: Min Level: 3.0%
[12:13:41][C][servo:016]: Max Level: 12.0%
[12:13:41][C][servo:017]: auto detach time: 0 ms
[12:13:41][C][servo:018]: run duration: 0 ms
[12:13:41][C][psram:020]: PSRAM:
[12:13:41][C][psram:021]: Available: YES
[12:13:41][C][captive_portal:088]: Captive Portal:
[12:13:41][C][mdns:094]: mDNS:
[12:13:41][C][mdns:095]: Hostname: default
[12:13:41][C][ota:085]: Over-The-Air Updates:
[12:13:41][C][ota:086]: Address: default.local:3232
[12:13:41][C][ota:089]: Using Password.
[12:13:41][C][api:138]: API Server:
[12:13:41][C][api:139]: Address: default.local:6053
[12:13:41][C][api:141]: Using noise encryption: YES
[12:13:41][W][esp32_camera:162]: Got invalid frame from camera!
