So I ran the All in one installer and had my mosquitto mqtt working well. I was publishing location from owntracks and trying to get smartthings bridge working. I tried changing around a bunch of settings and I think I ended up breaking it.
I can currently get mosquitto running, on boot with no problem. HA doesn’t throw any errors for it in the log (Only error is 17-01-10 14:20:49 netdisco.ssdp: Error fetching description at http://192.168.0.254:49152/wps_device.xml). In command line I can subscribe to /# and I can command-line publish topics and it receives them. From HA, however, I can no longer seem to successfully publish topics. It calls publish, but I never see it show up.
in configuration.yaml, I have this code for the mqtt
mqtt:
broker: 192.168.1.216
port: 1883
client_id: home-assistant-1
username: user
password: pass
I set up sudo mosquitto_passwd -c /etc/mosquitto/pwfile user with password pass. I had previously deleted the file and recreated it in my struggles.
my config.yml for mqtt is … very large because it is super descriptive since AIO created it. I had changed the port and listener, but they are currently
#port 1883
port 1883
listener 9001
#listener 1883
protocol websockets
I’ve been following BRUH Automation’s guide for this, and I definitely had it working but broke it somehow. I’m not sure if there is something in one of these files that is still broken, or if i am completely blind to another file or setting that might be broken.
Help is appreciated.
