Air Gradient Could not find one of 'package.json
Hi All
I have some issue while trying to flash Air Gradient with ESPhome,
The yaml i am using is from MallocArray Github
is there any suggestion on how to solve on this issue?
Full Yaml
# AirGradient ONE - Board v9
# https://www.airgradient.com/open-airgradient/instructions/overview/
substitutions:
  friendly_name: "AG One"
  config_version: 2.0.1
  name_add_mac_suffix: "false"  # Must have quotes around value
# Enable Home Assistant API
api:
  encryption:
    key: "  "
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Main-Area-Airgradient"
    password: ""
dashboard_import:
  package_import_url: github://MallocArray/airgradient_esphome/airgradient-one.yaml
  import_full_config: false
packages:
  board: github://MallocArray/airgradient_esphome/packages/airgradient_esp32-c3_board.yaml
  pm_2.5: github://MallocArray/airgradient_esphome/packages/sensor_pms5003.yaml
  co2: github://MallocArray/airgradient_esphome/packages/sensor_s8.yaml
  temp_humidity: github://MallocArray/airgradient_esphome/packages/sensor_sht40.yaml
  tvoc: github://MallocArray/airgradient_esphome/packages/sensor_sgp41.yaml
  display: github://MallocArray/airgradient_esphome/packages/display_sh1106_multi_page.yaml
  led: github://MallocArray/airgradient_esphome/packages/led.yaml
  led_co2: github://MallocArray/airgradient_esphome/packages/led_co2.yaml
  airgradient_api: github://MallocArray/airgradient_esphome/packages/airgradient_api_esp32-c3.yaml
  hardware_watchdog: github://MallocArray/airgradient_esphome/packages/watchdog.yaml
  config_button: github://MallocArray/airgradient_esphome/packages/config_button.yaml
  wifi: github://MallocArray/airgradient_esphome/packages/sensor_wifi.yaml
  uptime: github://MallocArray/airgradient_esphome/packages/sensor_uptime.yaml
  safe_mode: github://MallocArray/airgradient_esphome/packages/switch_safe_mode.yaml
binary_sensor:
  - id: !extend config_button
    pin:
      ignore_strapping_warning: true  # Acknowledging that this is a strapping pin and should not have external pullup/down resistors  https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Error Message
INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/air.yaml...
INFO Updating https://github.com/MallocArray/airgradient_esphome.git@None
INFO Generating C++ source...
INFO Compiling app...
Processing airgradient-one (board: esp32-c3-devkitm-1; framework: arduino; platform: platformio/[email protected])
MissingPackageManifestError: Could not find one of 'package.json' manifest files in the package
<sub>Text</sub>
