I’m using the built in Airthings web integration for an Airthings View Plus device that is configured on my network and properly sending data to the cloud. I have created the api key and configured the integration.
From the Airthings app (on my phone), I can see that there are 8 sensors being reported, plus battery level.
The HA Airthings integration has only has 7 sensors (including battery) . It has left out the radon and pressure sensors.
What do I need to do in order to get the missing sensors reported in HA?
Then the integration does not support them.
A feature request listing the specific integration and the example integration that has it as an example, etc, might get you somewhere.
Also if you look in core documentation, the owner might be listed.
Not sure what’s going on here. Can you enable debug logs and post it here? Make sure it has fetched data a few times, wait 15 or so minutes to be sure.
Final update: with help from @LaStrada, we decided to delete the device from the integration, and then add it again (with the same id and secret values).
This cleared it up, I’m now seeing all of the sensors.
Many thanks for the very quick turn-around on this! It’s amazing to see this level of support.
FWIW, I also don’t see Radon reflected from my new View Radon…but it does show as “N/A” in their native web app. So I suspect their API doesn’t even include it in the API call before it is defined. I did delete and re-add, no change. So sometimes, it might just take a few days.
