The spill zone selection can’t be changed without reconfiguring the AirTouch in Home Assistant (it’s part of the AirTouch installation settings and not expected to change). However, the selection is only used for the zone spill sensor (to indicate whether the sensor is being used for spill or not) and the spill percentage sensor. If you’re not worried about those you could just choose bypass. If you pick multiple zones the spill on/off sensors will work but the spill percentage sensor won’t.
There is an automation linked from the readme here which does this:
Take a look at the actions in the automation for an example of how to reset the control method.
Let me know if it doesn’t make sense.
@TheNoctambulist Ben, how would I reconfigure it? I would like to have the spill sensors for each room Would I have to reinstall the component, or re-initialise it somehow? I’d rather not have to since I renamed all the entities slightly to make sense to me.
I’ll have a look at the example automations in a day or two, thanks
You’ll need to delete and re-add the AirTouch device from the integration settings page to change the spill zone. All the entities are created with deterministic unique IDs, so I think Home Assistant will keep any renames etc.
If you plan to change the spill zone regularly, then the best bet is probably to select both zones as spill zones when setting up the integration. Then you will get the individual spill sensor for each zone. The only downside would be that the spill percentage sensor will always be +100% over the actual value , but that could easily be worked around with a template sensor.
I change the spill zone quite regularly. The system wasn’t installed all that well, and we get quite a bit of spill. In heating mode we usually want the lounge to be warmer than bedrooms so we set the spill there. We like bedrooms cooler than the lounge for sleeping, like most people, so in cooling mode we’d rather have the bedrooms a bit cooler than cool down the lounge where we watch TV and such.
I’ll add every zone as a spill zone. I’ll be able to create a sensor to compensate, or just work with whatever values it has. I’ll be experimenting to start with, if I have to reinstall it a few times to get it right that’s ok
