What you are mentioning is the bug and you need to contact Airtouch to have it sorted out.
It’s an android issue and the patch update or latest console will resolve the issue.
Maybe message me your details and Airtouch ID and I can put you in contact with someone that can assist correctly.
Hi
Thanks for confirming! Is there a way to know if we just need the SD card update or if we need a new console?
I ended up organising for someone from Polyaire to come by and do the SD card update on Monday so hopefully will have it all sorted then.
Not related to the integration but related to AirTouch and Home Assistant…
I’m running the home assistant app on my airtouch and using it as a dashboard. I’m using this integration of course and it’s displayed on the dashboard. I dont want to use the airtouch app as a UI anymore.
The issue I have is that the tablet is often closing Home Assistant - possibly because it’s running out of memory or something. I often walk past it and it’s just showing my “desktop” ie android wallpaper and icons.
Does anyone have any solutions to this?
The Airtouch console isn’t really that powerful and its main purpose is as a AC controller/interface to the Airtouch main module. This would have been done at the time as it’s cheaper to use that screen while giving home owners access to other apps to become more of a home central hub/station.
Because of this, the android version is locked and many other android features are locked to suit it.
Every time the system reboots or needs to it will load into the Airtouch app by default.
Personally, I wouldn’t be using it for your purpose or trying to fight it really.
I have a standalone Samsung galaxy tablet wall mounted to do everything and the Airtouch is hidden away.
In the future things will be different though
The Airtouch application has to stay running on the tablet otherwise home assistant can’t connect. The Wi-Fi interface to Airtouch is in the tablet.
The tablets run Android Go, which is for low-powered devices. Some of the defaults regarding background apps etc are quite conservative.
IIRC, if you go into battery settings, you can disable battery optimizations for the HA companion app (and make sure they’re also disabled/unrestricted for all the Airtouch components), and this should reduce the likelihood of it being killed off. There’s also a setting somewhere that limits how many (if any) background apps can be running at once. I believe the setting is ‘Background usage limits’ or similar.
But as @smitcoracing said, it’s not really meant to run anything other than Airtouch, so HA may still crash even after doing this.
Yeah, I also tried this but gave up. The tablet is just too under-powered to do anything useful. Best to just leave it to do AirTouch and nothing else.
Yeah you can make the Airtouch app run longer if it’s not in the foreground, but Android seems to kill it eventually if it’s in the background. I think the Airtouch app needs to stay in the foreground in practice. Different versions of the console may be different though.
Curious where you have the airtouch hidden away? Presumably it needs to be on and connected to wifi for connectivity features.
I’m curious to leave it in my roof cavity but worried it will fry in the summer. Alternative is just to wall mount it somewhere out of the way.
Mine is wall mounted away in a room where it isn’t visible.
The roof space would be too hot and not ideal if you need to get to it for some reason.
I need help.
We have a Panasonic ducted inverter system installed with AirTouch 5. It has 6 zones and one of those zones is set to the dreaded spill zone. Actually they set an additional spill zone to the master bedroom. The system was installed in December but we’ve only just recently started using it for winter. I have a few issues and still trying to get my head around it all.
Firstly, I cannot access the installer password as it’s coming up with a box labelled installer locked. The default password Polyaire does not work. The installation company is not returning calls or emails. I would like to check the settings. How do I reset this password?
I have the fan on auto but don’t know if this is the best choice.
I have set up programming. When the night program ends the whole system locks and I cannot access it. Is this normal? I have been experimenting with turning the system off over night as I originally had it programmed with the minimum set point of 16 but it kept coming on overnight constantly. One of the kids bedrooms has the worst airflow in the system and the company don’t want to do anything about it. It keeps dropping below set point. Without the heating being on the house gets very cold overnight and I worry it has to work too hard in the morning to reheat so I’m torn as to what to do overnight. Run it or turn it off.
There are more issues like the spill zone going over set point because of the lag in some rooms reaching set point as well.
Our system is running through the floor as it replaced an old gas ducted system. We are in freezing Canberra.
Possible issue with the integration and using Intelligent Auto via console.
I can set the fan speed on the console to auto and reload the integration - everything works.
When I set the fan speed on the console to intelligent auto, nothing immediately stops, however as soon as I reload the integration again, I get the below error in the debug log trace:
2025-06-05 11:17:51.328 ERROR (MainThread) [pyairtouch.comms.socket] _read(): Unexpected exception in socket handling
File "/usr/local/lib/python3.13/site-packages/pyairtouch/comms/socket.py", line 349, in _read
read_result = await self._read_one_message()
File "/usr/local/lib/python3.13/site-packages/pyairtouch/comms/socket.py", line 416, in _read_one_message
message_result = message_decoder.decode(message_buffer, header)
File "/usr/local/lib/python3.13/site-packages/pyairtouch/at5/comms/xC0_ctrl_status.py", line 211, in decode
sub_message_result = sub_message_decoder.decode(
buffer[_SUB_HEADER_STRUCT.size :], sub_header
File "/usr/local/lib/python3.13/site-packages/pyairtouch/at5/comms/xC023_ac_status.py", line 286, in decode
fan_speed=self._decode_fan_speed(b2),
File "/usr/local/lib/python3.13/site-packages/pyairtouch/at5/comms/xC023_ac_status.py", line 315, in _decode_fan_speed
return AcFanSpeed(fan_speed_raw)
File "/usr/local/lib/python3.13/enum.py", line 726, in __call__
return cls.__new__(cls, value)
File "/usr/local/lib/python3.13/enum.py", line 1201, in __new__
raise ve_exc
ValueError: 8 is not a valid AcFanSpeed
Turning the console back to Auto and reloading the integration fixes the issue and control restored to the HA integration side.
Found this by looking for that
sensor.<ac_name>_active_fan_speed
entity but couldnt find it & reload integration while in intelligent auto mode.
AT5 with panasonic + bypass w/ 7 zones + ac auto installed this year fyi
I sent a message earlier, but just so others know, I suggested you call the installer daily until they fix what sounds like an expensive system, and also call Polyaire for help. Polyaire may have someone else in the area who can help you if your installer refuses to help, and I guess they might stop selling their gear to installers who leave customers in the lurch.
I always select my fan speed manually. High for fast heating, medium most of the time, low overnight. I always keep the system on overnight in winter. When it’s really cold I don’t turn it off at all, I just reduce the temperatures during the day in areas we’re not using.
The temperature dropping below the setpoint is normal. It will usually go about 0.5 degrees below and then heat to 0.5 degrees above but might get down to a degree below sometimes, that’s expected. You can increase the setpoint a degree if you need to.
Spill zone going over setpoint is normal as well. To fix that you want a bypass damper, which your installer can fit if you can get them to turn up.
Thanks Tim. Installer failed to call back again today. My husband wanted to give him another chance, but tomorrow I will insist we call Polyaire instead. I still can’t unlock the password and did try Polyaire with a capital P.
I always use the program function for running the heater. I guess that’s because it’s the way I operated the old gas ducted system. That’s why I had it programmed to auto fan. I set both the zones and the AC in the program settings. I’m not sure if this is the most efficient way though. It was so cold last night. I don’t like that the minimum setting for the set point is 16. I left the heater off last night and all our zones dropped to 13 degrees or below! One was 11 and another 12. That is crazy when we upgraded our ceiling insulation last year. The room that hit 11 has a lot of space under the floor due to the slope of the land. I’m wondering if this is the problem here. I’ve just discovered away mode and might try that at 14 so the temp doesn’t drop so far. It’s still going to set it off regularly through the night though. I only have the heater set to 17 at wake up.
I will set the heater at low fan overnight as you suggest.
We set our bedrooms to 20 overnight, in a house with good insulation, double glazing, etc. Generally 16 to 19 is recommend for bedrooms, but my wife likes it warm. The height of the sensors from the ground can make a difference too.
Suggest you set your bedrooms to whatever of the available temperatures you prefer which sounds like 16, turn off other rooms like kitchen overnight, disable all automations and programs, set it to low fan and leave it alone until morning. I think you’ll find it works better that way, once you’re used to it you can try programs again.
A fan speed value of 8 doesn’t match anything in the interface specification which is causing the error.
@benderrodrigo could you please turn on debug logging on the integration settings page, then reload the integration or restart Home Assistant, put the AC into Intelligent Auto mode to trigger the error, then disable debug logging and send me the file that is automatically downloaded. I can look into the debug logs and try to work out what is different with your system.
Have messaged you, I can sort this out ![]()
Hey I saw this message and was curious about your settings.
I’ve got a Mitsubishi with AT5 and sensors in all rooms. We’ve got a pretty poorly insulated house (paper thin windows and rubbish walls - we’re going to redo the extension though so that’s a later problem, old part of the house is double brick and retains temp well).
You mention you leave it on all the time. What’s your daily energy usage? I suspect maybe minimal because of good insulation?
Also wanted to ask about your settings. Do you find the system maintains temp well when the fan is set to low? We don’t have a bypass duct (I’m looking into it with AC guys, our original installer ghosted us). When it was installed they put in a vent in the hallway at the opposite end of return air that is just always open. I’ve closed the fins as much as possible and the living room is the spill zone but I find the system can overshoot set temp (especially in the living room) by at least 1°
Any thoughts here? I’d like to avoid turning on/off the compressor as I think that’s when we get huge power spikes. We’re getting a home battery soon as well so hopefully can run the ac continuously off solar to have the house equilibrate then maintenance during peak rates
I use various fan speeds, which I automate with HA. For specific scenarios such as turning the heat on to preheat the house in the afternoon before we get home I manually select high fan, which I switch down to medium after about an hour or so.
For the evenings, when our dampers are open over 200% HA automatically selects high fan, when it’s below 90% it selects medium fan. The sensor to add the dampers up and the automation to change fan speeds is quite simple but I can post if anyone wants it.
I use low fan exclusively overnight. Given it’s only heating the bedrooms, and the doors are closed, it works great. The outdoor Daikin unit seems to use less power when the fan is low, which just means it’s turned on a little longer, but heat pumps can be more efficient at lower power levels sometimes. We have wall vents low down in the walls so the heat is drawn across the rooms.
Energy usage will differ between houses, of course. Old cold says I leave the system on with low temps even for rooms we’re not using for many hours, like bedrooms, because otherwise heating them up from very cold later takes quite a while. It’s more about comfort than power usage, but based on some rough tests I did a few years ago I don’t think it uses all that much more power than turning it off and then turning it on later in the day. This is with an old house, double glazed, and with ceiling, wall, and under-floor insulation, so probably nowhere near as good as new houses but not bad.
