AJ_SR04M via UART and 3x Dallas sensors with ESP32 for water tank measurements and hot water of boiler
Guys,
Long time ago with the assistance of community I had achieved to setup an ESP32 project for measuring
1)the level of my storage water tank, converting to liters and percentage of capacity and
2) the temperature of solar panel and boiler hot water via 3x dallas sensors.
It was working quite good, In general I was satisfied with performance of ultrasound measurements although in higher distance it was problematic in the sense of accuracy.
Dallas sensors were fine, performing well and I wasn’t thinking to touch it ever!
Few months ago, after an update of ESPhome noticed that sensors are not providing data anymore and when trying to update or to reboot, it was coming an error of
INFO ESPHome 2025.3.2
INFO Reading configuration /config/esphome/esp32-sensors.yaml…
Failed config
sensor.custom: [source /config/esphome/esp32-sensors.yaml:24]
The ā€œcustomā€ component has been removed. Consider conversion to an external component.
Contributing — ESPHome.
Presently my board, named as ā€œESP32-sensorsā€ is stucked with ver 2024.12.4 without being able to update to 2025.3.2
or even run it and have measurements.
As I have no idea for whta is talking about or what is the external component or how to compile it,
I’m adressing the situation to the community and seeking for assistance to bring it back to life.
I have (apart the installed ESP32+AJ_SR04M) a spare mini ESP32 that prooved to be… burned or bricked, an ESP32 on the way from china to my home, an extra AJ_SR04M for experiment and quite few time as pensioner.
Here is the esp32-sensors.yaml and the AJ_SR04M_Sensor.h at
esp32-sensors.yaml
esphome:
  friendly_name: ESP32-sensors
  includes:
    - AJ_SR04M_Sensor.h
esp32:
  board: esp32dev
  framework:
    type: arduino
one_wire:
  - platform: gpio
    pin: GPIO22
uart:
  tx_pin: GPIO32
  rx_pin: GPIO33
  baud_rate: 9600
  stop_bits: 1
  rx_buffer_size: 4
  - platform: custom
    lambda: |-
      auto my_sensor = new AJ_SR04M_Sensor(id(uart_bus));
      App.register_component(my_sensor);
      return {my_sensor};
    sensors:
     unit_of_measurement: cm
     accuracy_decimals: 1
     filters:
      - median:
         window_size: 19
         send_every: 20
         send_first_at: 1
      - filter_out: nan
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      unit_of_measurement: Ltrs
      name: "Tk Quantity"
      filters:
      - lambda: return ((229.0*143.0*(210.0 - x))/1000.0);
      - median:
         window_size: 29
         send_every: 30
         send_first_at: 3
      - filter_out: nan
  - platform: custom
    lambda: |-
      return {my_sensor};
    sensors:
      unit_of_measurement: pct%
      name: "Tk space pct"
      filters:
      - lambda: return ((((229.0*143.0*(210.0 - x))/1000.0)/6877.0)*100.0);
      - median:
         window_size: 29
         send_every: 30
         send_first_at: 3
      - filter_out: nan
  - platform: dallas_temp
    address: 0xea0722b0dcbabc28
    name: "Boiler Hot water"
    address: 0xd30822b0f48ffd28
    name: "Boiler Diesel Inl."
    address: 0xa90722b0e5ac1328
    name: "Boiler Solar Inl."
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  platform: esphome
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
captive_portal:
web_server:
  port: 80
globals:
  - id: last_state
    type: float
    restore_value: no
    initial_value: '0.0'
and AJ_SR04M_Sensor.h from /homeassistant/esphome/
#include "esphome.h"
class AJ_SR04M_Sensor : public PollingComponent, public UARTDevice, public Sensor {
  public:
    float last_state;
    float old_state;
    AJ_SR04M_Sensor(UARTComponent *parent) : PollingComponent(5000), UARTDevice(parent) {}
    void update() override {
      old_state = last_state;
      //ESP_LOGD("Start", "Last: %.2f", old_state);
      byte frame[4];
      int pos = 0;
      float value = 0.0;
      //write(0x00); // Try this
      write(0x01); // Try this
      //write(0x55); // Try this AJ_SR04M
      //write(0xFF); // Try this DYP-A12BNYTW-V1.0
      while (available()) {
        frame[pos] = read();
        //ESP_LOGD("Hex", "Hex: %X", frame[pos]);
        //pos++;
        if (pos == 3) {
          //ESP_LOGD("Validation", "pos == 4");
          //if ((frame[0] == 0xFF) && (frame[4] == 0x00) && (((frame[0] + frame[1] + frame[2]) & 0x00ff) == frame[3])){
          if ((frame[0] == 0xFF) && (((frame[0] + frame[1] + frame[2]) & 0x00FF) == frame[3])) {
            //ESP_LOGD("Validation", "SUM");
            value = ((frame[1] << 8) + frame[2]) / 10.0;
            publish_state(value);
            last_state = value;
            //ESP_LOGD("Start", "Last: %f", last_state);
          break;
        pos++;
Does anybody could fix this? or compile this external component for me? or provide any kind of help to set it up in another but functional way?
Thanks!
You might want to change the category of your topic to esphome.
Also, did you try with stock component?
From what I can recall by memory, that time only working option was via uart method. Few good guys helped me (here) to make it running.
The component I posted above uses uart.
Hi, just got a new esp32 board and I can do some experiments without touching the initial setup. Could you post your config file for copying to my experimental system?
You could use the following which restores the ā€˜custom’ functionality;
