Hey everyone,
I've been using the excellent ajax-security-hass HACS integration by foXaCe for a while, and like many of you I hit the same wall — Ajax doesn't expose a local API, so you're dependent on their cloud, and the integration requires direct Ajax Enterprise API credentials which most end users can't get.
I built Ajax Connect to solve this. It's a cloud proxy service that sits between Home Assistant and the Ajax Cloud API, so you don't need your own Ajax Enterprise API key — you just point foXaCe's integration at the proxy URL and go.
How it works
Home Assistant (foXaCe HACS integration — Proxy Mode)
↓ SSE + REST
Ajax Connect Proxy (api.ajaxconnect.app)
↓ Ajax Enterprise API
Ajax Cloud
Your Hub
No changes to foXaCe's integration are needed. If you already have it installed, switch it to Proxy Mode, enter the proxy URL, and your existing Ajax credentials — done.
What you get
• Real-time events when armed — arm/disarm, alarms, and malfunction events delivered via SSE the moment they arrive from Ajax SQS
• Real-time push when disarmed — the proxy polls Ajax once per hub and pushes door open/close, motion, relay state, battery, leak, and smoke events to HA instantly (foXaCe's native 30s poll delay is eliminated)
• Bidirectional control — arm, disarm, night mode, and device commands from HA work as expected
• All device types — DoorProtect, MotionProtect, LeaksProtect, FireProtect, Relay, KeyPad, StreetSiren, cameras, and more
• Multi-hub support — multiple Ajax hubs from one HA instance
• AES-256 credential encryption — your Ajax credentials are never stored in plaintext
Pricing
• 7-day free trial — no card required, activate immediately
• Starter — $3 USD/month — 1 hub
• Pro — $5 USD/month — up to 3 hubs
PayFast and Paystack accepted.
Verified hardware
Developed and tested against a real Ajax Hub 2 Plus with a full device set — DoorProtect, MotionProtect, LeaksProtect, FireProtect, Relay, StreetSiren, KeyPad, SpaceControl, and more.
Links
• Website + free trial: https://www.ajaxconnect.app
• FAQ: Ajax Connect FAQ — Ajax Security + Home Assistant Integration
• foXaCe's integration (required): GitHub - foXaCe/ajax-security-hass: Home Assistant integration for Ajax Security Systems · GitHub
Happy to answer questions. If you're running Ajax and HA this should just work.
