Aladdin Connect Workaround 2025
New to the forum, so don’t roast me, lol.
I wanted to put in a simple/hacky workaround for those who want to control their Aladdin garage door since the integration was disabled last year. I have read a lot about scripting and complex workarounds, but let me tell you what worked for me:
Requirements:
  • Amazon Alexa
  • Any smart plug (I use these extensively, they work great) - via Amazon: Smart Plug 5GHz, EIGHTREE Smart Plug Works with Alexa & Google Home, 5GHz & 2.4GHz WiFi Compatible, with Remote Control & Timer Function, 4 Pack
Steps:
  1. Add your Aladdin garage door to Alexa. Once you do so, make sure it works by testing it out like “alexa, open my garage door,” etc.
  2. Add the smart plug to your HA and name it something like “Garage Door.” You don’t need to plug anything in it, you just need a switch for the automation.
  3. In the Alexa app, create two routines:Routine 1
  • When this happens → SMART HOME → Garage Door Socket → Close
  • Alexa will → CUSTOM → “close garage door”Routine 2
  • When this happens → SMART HOME → Garage Door Socket → Open
  • Alexa will → CUSTOM → “open garage door, voice code [XXXX]
    • (It will warn you to be careful when embedding pin numbers - but you need to if you want it to work without the voice confirm step.)
  1. Add a button/event/trigger to HA.
  2. You now have a button that opens and closes your garage door.
Loving this idea but isn’t there a way to create a fake switch in HA rather than have an actual switch dedicated to … to do nothing?
