Logger: pyalarmdotcomajax
Source: /usr/local/lib/python3.13/site-packages/pyalarmdotcomajax/__init__.py:583
First occurred: 11:22:21 AM (2 occurrences)
Last logged: 11:31:51 AM
pyalarmdotcomajax _async_get_identity_info: Failed to get user's identity info.
File "/usr/local/lib/python3.13/site-packages/pyalarmdotcomajax/__init__.py", line 573, in async_login
self._provider_name = json_rsp["data"][0]["attributes"]["logoName"]
KeyError: 'logoName'
and
This error originated from a custom integration.
Logger: custom_components.alarmdotcom.config_flow
Source: custom_components/alarmdotcom/config_flow.py:102
integration: Alarm.com (documentation, issues)
First occurred: 11:31:51 AM (1 occurrences)
custom_components.alarmdotcom.config_flow: user login failed with AuthenticationFailed exception.
File "/config/custom_components/alarmdotcom/controller.py", line 141, in initialize_lite
await self.api.async_login()
File "/usr/local/lib/python3.13/site-packages/pyalarmdotcomajax/__init__.py", line 587, in async_login
raise AuthenticationFailed from err
pyalarmdotcomajax.exceptions.AuthenticationFailed
File "/config/custom_components/alarmdotcom/config_flow.py", line 102, in async_step_user
await self._controller.initialize_lite(
...<3 lines>...
File "/config/custom_components/alarmdotcom/controller.py", line 147, in initialize_lite
raise ConfigEntryAuthFailed from err
homeassistant.exceptions.ConfigEntryAuthFailed
Yes, appreciate the input. The GitHub link above has a fix for the ‘issue’ - though I’m personally on HAOS and makes it much harder to find/edit the file.
I am a newbie to HA, and you fine people are talking over my head with this code.
I had Alarm.com working by installing HACS. With a recent update, HA Alarm.com asked me to log in. Well, it fails. I cannot do 2FA, and I cannot remove 2FA from Alarm.com since it is required now.
Kindly in language I can understand, is it broken and no fix for Alarm.com with HA?
If not, since I used the GUI and not code. How do I log in now with 2FA required?
UPDATE. @elahd was able to update the code and an update has been pushed out. Ensure your HACS version of Alarm.com is at least 3.0.14 (latest currently) and this issue should be fixed.
