Alarm.com sensor not working
Trying to get my Alarm.com sensore to show open and closed status. I have it set up and it’s there,but opening and closing the door doesn’t do anything…
  sensors:
      alarm_frontdoor:
        friendly_name: "Front Door"
        device_class: door
        value_template: >-
          {{ state_attr('alarm_control_panel.alarm_com', 'sensor_status')|regex_search('Front Door is Open', ignorecase=TRUE) }}
Try this
        value_template: >-
          {{ state_attr('alarm_control_panel.alarm_com', 'sensor_status')|regex_search('Front Door is Open', true) }}
The docs are a bit confusing. I might try clarifying them with some examples.
Ok,I’ll give it a try.
I tried it and still nothing. It shows closed,but not open when door is open.
Can you post a screen-shot of the sensor_status attribute value (Developer Tools States Menu)?
As that regex was working for me when I tested it.
And another test:
Alright,let me check.
I can’t find anything that looks like your screenshot,so I’m not sure what I’m doing wrong. The only thing in attributes for that sensor is…
friendly_name: Front Door
device_class: door
Or go to the Template section on that page, and past in:
{{ state_attr('alarm_control_panel.alarm_com', 'sensor_status') }}
Ok, now paste this into the template editor:
{{ state_attr('alarm_control_panel.alarm_com', 'sensor_status')|regex_search('Front Door is Closed', true) }}
Nice. It correctly matched your closed front door.
Now open your front door and paste this in the template editor:
Ok,it’s working now. I was about to say t wasn’t,but there is a 10 second delay for status changes.
Now do I repeat the same template for the Side door?
Appreciate the help.
Tried making one for the Side door using the same template,but changing the name and it doesn’t even show up.
So something like this?
  sensors:
      alarm_frontdoor:
        device_class: door
        value_template: >
      alarm_sidedoor:
        friendly_name: "Side Door"
        device_class: door
        value_template: >
          {{ state_attr('alarm_control_panel.alarm_com', 'sensor_status')|regex_search('Side Door is Open', true) }}
That was it. I forgot to change alarm_frontdoor to alarm_sidedoor. Everything is good now. Appreciate the help tom. :+1:
I am having a similar issue, here is my yml
binary_sensor:
sensors:
# Contact Sensor
alarm_front_door:
friendly_name: “Front Door”
device_class: door
value_template: “{{ state_attr(‘alarm_control_panel.alarm_com’, ‘sensor_status’)|regex_search(‘Front Door is Closed’, true) }}”
I keep getting this error
Invalid config for [alarm_control_panel.alarmdotcom]: [binary_sensor] is an invalid option for [alarm_control_panel.alarmdotcom]. Check: alarm_control_panel.alarmdotcom->binary_sensor. (See ?, line ?).
this line works perfectly in my template editor, what am I missing?
