Alarm Control Panel: boolean switch control
I want to change the status of the Alarm Control Panel with a boolean switch.
For example
off = disarm
on = arm_home
The other way around, the alarm control panel should also report its status to the boolean switch.
I’ve already experimented a lot with the Template Alarm Control Panel here. Unfortunately without success.
What is the best way to do this?
alarm_control_panel:
  - platform: manual
#    code: '1234'
    arming_time: 0
    delay_time: 0
    trigger_time: 1200
    disarm_after_trigger: false
    disarmed:
      trigger_time: 0
    armed_home:
      arming_time: 0
      delay_time: 0
    panels:
      alarm_home:
        value_template: "{{ states('input_boolean.alarmanlage_scharf') }}"
        arm_home:
          service: alarm_control_panel.alarm_home
            entity_id: input_boolean.alarmanlage_scharf
        disarm:
Hi
Did you solve the problem?
