I have recently setup my AD2PI to be integrated in with my HA. Almost everything works fine.
I utilized the code at https://www.home-assistant.io/integrations/alarmdecoder/#chime-status-and-control
but am getting the following errors when actuating the toggle.
[547578874512] sequence item 0: expected str instance, Optional found
1:15:48 PM – Home Assistant WebSocket API (ERROR)
Chime: Error executing script. Unexpected error for call_service at pos 1: sequence item 0: expected str instance, Optional found
1:15:48 PM – helpers/config_validation.py (ERROR)
I’m not sure where to start to trouble-shoot this. I have added my code into the secrets.yaml
Any insight is appreciatted.
