šŸ“¢ [Alarm] Keypad Frient (KEPZB-110) for Alarmo or Other Systems with ZHA
Works
Thank you very much for the job
It works
I don’t understand everything happen on keypad but my child and me (and my wife) can enable/disable alarm without connect to home assistant.
A complete description of each field (what to set and where to find) will be very helpfull
find tag rfid
Home assistant → dev tool (outil de dĆ©veloppement with me) → evenement dongle → listen event ā€œzha_eventā€ and click on start listen.
Tag your rfid and click on open ā€œcadenaā€
You can find in an event the tag rfid : +89ABCDEF
Good luck
I saw that this blueprint hasn’t been updated for about 2 years.
I tried it first with my Frient Keypad, but I couldn’t get it working 100%. I put the code into ChatGPT, which corrected and fixed all the errors it found in the code. With ChatGPT’s help, everything works now.
If anyone wants my code, just PM me.
Hi !
Couldn't make the blueprint work so I ended-up making my own automation : GitHub - edouardmenayde/frient_keypad_control_zigbee Ā· GitHub
You have to modify some strings as instructed in the README then upload it as an automation.
Cheers,
