Alarm Panel / Envislink Display Options after 2024.6.2 Release
Hello! I use the alarm panel card to monitor and control my honeywell / envisalink alarm system. Prior to 2024.6.2, the card would simply display the status and have a button for Arm and Disarm. Now it’s also displaying the alarm panel keypad numbers. Any idea how I remove the keypad, since I had buttons for arm and disarm, without the need to enter a code (which already in my ymal file).
Anyone with the same problem, I found this open ticket:
https://github.com/home-assistant/core/issues/119443
Seeing the same issue with my mqtt alarm, it now displays indeed a huge keypad, that I don’t need…
Found a solution?
One option is to use card_mod to hide it
states:
  - arm_away
type: alarm-panel
entity: alarm_control_panel.ha_alarm
card_mod:
  style: |
      #keypad {
       display: none !important;}
      ha-textfield {
I recently found, and installed, envisalink_new via HACS. It works much better, and will also migrate your existing envisalink config from configuration.yaml.
It is found at https://github.com/ufodone/envisalink_new
Hopefully this one day will take over from the existing old, and outdated, envisalink integration.
