🚨 Alarm System with ZHA Keypad support (KEPZB-110)
Not sure if others are experiencing issues with the Keypad starting with ZHA in HA 2025.3.0. I’ve been experiencing that the Keypad keeps changing modes in the Keypad internally, even though the state in HA doesn’t change.
Whenever I send 1 command it keeps switching between an armed/disarmed state. I can fix it by fully removing it from ZHA and repairing it. But the problem comes back from time to time. Sometimes it kept going until I removed the batteries…
So I’ve decided to move the Keypad to Z2M on a separate HA Connect ZBT-1 and created a new blueprint based on this one to be compatible with Z2M.
:orange_book: Z2M version
Big advantage of the Z2M implementation is that it supports all states, so you also get the pending and arming states with proper green/red and beeping states. This is sadly not implemented in ZHA itself.
