Curious if the alarmdotcom integration (https://www.home-assistant.io/components/alarmdotcom/) has the ability to be configured with multiple locations.
I have it setup both at work and home (two systems). I’ve created a separate login where the primary location is different and trying to setup configuration.yaml like so:
alarm_control_panel:
platform: alarmdotcom
username: !secret alarmdotcom_user_work
password: !secret alarmdotcom_pass_work
Unfortunately, only the second location is registering. Has anyone successfully implemented a similar setup - or is my code off and therefore causing the issue?
Thanks in advance for any / all help!
