I need help installing Alarmo manually!
I am running Docker with Home Assistant, Frigate, and Z-Wave JS containers that communicate together.
I followed directions for manual installation of Alarmo:
I unzipped the file to my custom_components folder with:
sudo unzip alarmo.zip -d /opt/home assistant/config/custom_components
But after shutdown and restart of both my Home Assistant Docker and my computer, the Alarmo panel still does not appear in Home Assistant, nor can I add it via the Add Integration button.
Please comment if you feel you can help! Or if you are succesfully using Alarmo with Home Assistant running in Docker!
