I’ve tried the following after installing via HACS:
- Reboot
- Shutdown and power on
- Cmd-Shift-R (on Mac) to refresh browser in Chrome
- Using an incognito window in Chrome
After going to the Integration menu, clicking “+” and searching for Alarmo, it does not show up in the list.
Anyone else having this issue?
brenthaag
(Brent Haag)
2
Does it show it as “downloaded” in HACS? Any other information you can share or screenshots?
Why not post this in the ‘official’ Alarmo thread instead of creating a new one???
IOT7712
4
Maybe its a HACS installation issue, not an Alarmo one.
Yes - it is downloaded to the /config/www directory.
IOT7712
6
Is that where you expect it to be? Not the HACS folder?
As per the official instructions, that’s where it’s supposed to be. However, I thought it would be under /config/custom_components.
IOT7712
8
Did you use HACS click button to install or a manual process? Maybe remove it and reinstall using the automated process?
I used the HACS method to download Alarmo. Haven’t tried removing and redownloading. I will try that.
IOT7712
10
Then their manual instructions are inconsistent with your observations and you should report it as a problem in GitHub.
I installed “Alarmo Card” instead of “Alarmo”. Installing “Alarmo” worked properly.
