This just recently started happening and I would appreciate some help with it if possible.
I run HA on the HA Green and the error is below.
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:136
integration: HTTP (documentation, issues)
First occurred: 6:08:53 PM (426 occurrences)
Last logged: 6:12:59 PM
Login attempt or request with invalid authentication from localhost (127.0.0.1). Requested URL: ‘/auth/token’. (HomeAssistant-Extensions-PushProvider/2025.2 (io.robbie.HomeAssistant.PushProvider; build:2025.1178; iOS 18.3.2) Alamofire/5.8.0)
Has anyone else had this issue? Thanks in advance.
Cal
MikeS
(Mike)
April 2, 2025, 1:36pm
2
hi @calvinwhitt , i am having the same issue, did you manage to resolve it?
Many thanks,
Mike
Sorry. I still have the issue.
Cal
MikeS
(Mike)
April 7, 2025, 6:55am
4
hi @calvinwhitt , I have the exact same issue, did you get it fixed?
Tnx!
Mike S
MikeS
(Mike)
April 7, 2025, 7:39pm
5
@calvinwhitt : update, i found the issue. My son installed the Home assistant app, but it was configured incorrect causing these issues. After adding the correct server and credentials, the errors dissapeared!
Hey Mike
I still have this issue. Does your son remember what server he had to install and how did he do it?
Thanks Cal
