Alarmo - Ring Keypad v2 - Ignore Sensor
Good evening,
my Keypad works well, when a Door senosr or anything else is open, manipulted etc. the keypad tells “Ignore the Sensor” and you need to hold the OK :white_check_mark: button to ignore it, then it activates.
But, when i activate it on HA Dashboard there is no notification or anything, it just didnt arm. I want also to arm it on Dashboard and get a possibility to say OK-Ignore. Does someone have solution/fix for it? i didnt find anything till now…
Hy Guys, at least i found it by myself, i installed via HACS the “Alarmo Card” and used it on the Dashboard, it supports bypas the sensors.
SOLVED.
