Alert if recorder dies
Anyone have a good automation / blueprint / alert / script / something to trigger klaxons if the recorder process dies? Last two days apparently all stats were just gone and I didn’t notice because I was away from home.
  1. Although it is an interesting task - a more important task is “minimize a possibility of Recorder death”.
  2. Can you see any error messages in Log at the moment when “recorder dies”? If yes - then you can create an automation triggered by event “sys_error_log” (if I am not mistaken), analyze a message - if it contains anything about “recorder dies” then do something.
it was some massive query that was blocking the recorder process, no log files associated with it, sadly. So need something to look for metrics not being committed.
Erm, I meant the “main log” - does it have any errors related to recorder.
