Alert in configuration.yml unable to find service notify.mobile_app_
I created an alert in configuration.yml but I keep getting the following error message:
2023-06-09 16:16:52.828 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/alert/__init__.py", line 205, in watched_entity_change
    await self.begin_alerting()
  File "/usr/src/homeassistant/homeassistant/components/alert/__init__.py", line 217, in begin_alerting
    await self._notify()
  File "/usr/src/homeassistant/homeassistant/components/alert/__init__.py", line 263, in _notify
    await self._send_notification_message(message)
  File "/usr/src/homeassistant/homeassistant/components/alert/__init__.py", line 293, in _send_notification_message
    await self.hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1857, in async_call
    raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service notify.mobile_app_derrick
The service is available in Developer Tools → Services and I am able to send a test alert. I also have several automations that reference notify.mobile_app_derrick and they have no issues running. I’m confused about what I am doing wrong. Below is a copy of my configuration.yaml as well. Thanks for your help.
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
# Example configuration.yaml entry
alert:
  garage_door:
    name: Garage is open
    done_message: Garage is closed
    entity_id: input_boolean.test
    state: 'on'
    repeat: 5
    notifiers:
      - mobile_app_derrick
script: !include scripts.yaml
scene: !include scenes.yaml
