Alert on pump current
I have succesfully set up a Sonoff POW to monitor the current being drawn by a pump. Took nearly a day but I got there!
- platform: mqtt
  name: "Main Pump Current"
  state_topic: "tele/Sonoff_POW/SENSOR"
  value_template: "{{value_json['ENERGY'].Current }}"
  qos: 1
  unit_of_measurement: "amps"
What I need to be able to do now is generate an alert using Prowl (which I’ve used elsewhere), to alert me when the current rises above a certain level.
I’m a bit stuck as to how to do this and would appreciate any pointers as to the right direction.
This is the automation I use for my sump pump:
- alias: 'Pump Notification'
    platform: numeric_state
    entity_id: sensor.tp_link1_cwatts
    above: 100
    service: notify.mypushbullet
    data_template:
      title: "Home Assistant says:"
      message: '{{now().strftime("%H:%M")}}h: Sump pump started - {{ states.sensor.tp_link1_cwatts.state }} W'
I use that wattage value, not the current and a different notification platform, but I hope it helps.
Thank you!
That helps.
How do I relate your “sensor.tp_link1_cwatts” to what I have?
Is it as simple as sensor.Sonoff_POW.Current?
Is there a way to test it without actually having the current go over the limit?
How does your sensor show up in the /dev-state window?
It will only have one ‘.’ in the name.
The domain is ‘sensor’ and the sensor name is probably something like ‘main_pump_current’ - be careful with the spelling, i.e. capitals vs. lower case.
Re. testing, I’m not sure if you can just set the value for the sensor in the /dev-service tab to something that’s above your trigger value.
I’ve played around with a few things and still aren’t getting there.
I think what I need to do is find a way to have
be recognised as an entity so that I can then act on it’s value.
Does that sound right?
If so, how is this done?
For testing, it can be triggered from the /dev-/state window like this:
This should trigger the automation, i.e. the notification.
With MQTT details, I’m out of my depth, though.
I wanted to look at it in more detail but haven’t managed to do so yet :frowning:
Don’t MQTT entities not just show up like ‘normal’ sensors?
If not, then somebody with more MQTT experience needs to jump in.
Brilliant!
That was all the help I needed. Thank you so much.
One last thing.
Above is above:
Below is below:
What is equal to?
Not really sure about equal - I’d probably define a range anyway, e.g.
above: 98
below: 102
Would you mind sharing your config once you’re done so that I have a working example whenI get around tackling MQTT?
And, in terms of testing the automation for the MQTT setup, I think you should be using something like this from the /dev-mqtt tab:
But you probably found that already.
Here’s what I now have:
- alias: 'Main Pump Blocked Notification'
    entity_id: sensor.main_pump_current
    above: 0.130
  - service: notify.prowl
    data_template:
     title: "Main Pump"
     message: "Current is high - possibly blocked"
- alias: 'Main Pump Stopped'
    below: 0.130
    data_template:
     title: "Main Pump"
     message: "Main pump is stopped"
It may require some fine tuning of the values and I may well use power instead of current when I’ve tested it.
Any thoughts on this?
I’m using the POW R2 to monitor current and power of a series of pumps. The pumps are controlled by a PLC via contactor and the POWs are set to PowerOnState 4 so that they remain on, independent of Hassio.
However, the POWs receive their power from the pump controller contactor. If the pump is turned off the POWs disconnect from WiFi, obviously.
I need to find a way to hack them so that the WiFi stays alive.
Anyone have any experience of this?
