Alert2 - a new alerting component
Hi @pcwii, glad you’re giving it a try!
Alert2 has a built-in alert, alert2.alert2_error, which notifies if Alert2 has a problem itself or if it sees another part of HA crash. By default those notifications go to persistent_notification. You can configure the behavior in your config. See the config section of the docs.
In your specific case, it looks like one of your HA components using a ScrapeCoordinator crashed. Is there a stack trace in your HA logs? I can take a look if you send it.
I could add a config flag to tell Alert2 to not notify when other parts of HA crash, but it seems like a good thing to know about.
-Josh
Wow, fantastic response. I actually didn’t see the obvious error with the scraping until you pointed it out. I am now searching to see what that issue is. Just an fyi the persistent notification was up to 80 messages since I posted. Maybe a feature to restrict duplicate notification messages might be worth while. Maybe re-display the message with a recurrence count.
Hi - the setting throttle_fires_per_mins will limit notifications and then optionally send a summary when the throttling has ended. And of course you can snooze/disable notifications for a particular alert.
With the persistent_notification notifier in particular, I just took a look and it seems possible to dismiss a specific notification and recreate it, so it should be possible to do something like what you suggest. However, the alert2_error alert fires on a number of different problem conditions, so if you did consolidate a bunch of alert2_error notifications into a single persistent notification with a number displayed, it might hide conditions you care about.
Thoughts?
J
First off I cleared up the error I was having.
Secondly, I am thinking that if there is some form of a unique ID (UID) for the alert that is generating the notification since there are different alerts that are triggered then the counts can be specific to the UID for that alert. It won’t prevent different alerts but it will prevent alerts for the same condition to be repeated.
Just thoughts
Thanks!
Hi All,
I just released Alert2 and Alert2 UI v1.10.1. The main change is support for genIdx and genPrevDomainName in generators to make it easier to set up a generator of staged alerts. So for example you can you say:
    alert2:
      alerts:
        - domain: test
          name: "low_disk_{{ genElem }}"
          condition: "{{ states('sensor.disk_free_gb')|float < genElem }}"
          supersedes: "{{ genPrevDomainName }}"
          generator: [ 20, 10, 1 ]
          priority: "{{ ['low','medium','high'][genIdx] }}"
          generator_name: g1
The above creates three alerts for progressively lower free disk space. Each alert supersedes the previous alert and each alert has a higher priority than the previous alert.
v1.10.1 also fixed a few bugs related to rendering config fields in the create popup.
@ian_p , want to give it a shot and let you know how it goes?
@pcwii , your idea is interesting. The single alert alert2.alert2_error fires for many different kinds of errors. So I’m not sure how to coallesce that particular alert in a way that doesn’t hide the variety of problems that might be going on. For other kinds of alerts, I can totally see each one taking up at most a single line in persistent_notification.
-Josh
Hey Josh, was away for a while but back and trying out the new versions!
Question, I’m having problems with supersedes. I want an alert to supersede another alert, both are generators.
I tried supersedes in a few different formats (YAML map and YAML flow), and none seem to work - I included all my various attempts inline in the conf code below. Here’s a version, where I want the freezing alert to supersede the low temp alert. I’m still using genRaw back from when other vars didn’t resolve I’ll try changing that back at some point.
But I can’t get the freezing alert to even be read for some reason.
I keep getting errors like this:
2025-03-06 08:47:29.557 ERROR (MainThread) [custom_components.alert2.util] unhandled_exception with stack Traceback for <Task finished name='Task-114165' coro=<AlertGenerator.async_update_rez() done, defined at /config/custom_components/alert2/entities.py:508> exception=UnboundLocalError("cannot access local variable 'err' where it is not associated with a value")> (most recent call last):
  File "/config/custom_components/alert2/entities.py", line 575, in async_update_rez
    report(DOMAIN, 'error', f'{self.name} Supersedes template trying to parse {sStr} returned err {err}')
UnboundLocalError: cannot access local variable 'err' where it is not associated with a value
    - domain: temperature
      generator_name: low_fridge_temperature
      generator: "{% from 'entity_name_state.jinja' import expand_with_remote -%}{{ expand_with_remote('sensor.fridge_temperature_alert_group') }}"
      name: "{{ genRaw }}_is_low"
      friendly_name: "{{ state_attr(genRaw,'friendly_name') }} is low temp"
      condition: "{{ states(genRaw) != 'undefined' and  states(genRaw) != 'unavailable' and states(genRaw)|float < states('input_number.fridge_low_temperature_alert_value')|float }}"
      delay_on_secs: 900
      message: "Low temp of {{ states(genRaw)|float }}"
      display_msg: "Temp: {{ states(genRaw)|float | round(1) }}"
      notifier: nowhere_group
      generator_name: below_freezing_fridge_temperature
      name: "{{ genRaw }}_is_below_freezing"
      friendly_name: "{{ state_attr(genRaw,'friendly_name') }} is below freezing"
      condition: "{{ states(genRaw) != 'undefined' and  states(genRaw) != 'unavailable' and states(genRaw)|float <= 33 }}"
      delay_on_secs: 600
      supersedes: { domain: temperature, name: "{{ genRaw }}_is_low" } <-- ONE TRY
      supersedes: "{ domain: temperature, name: {{ genRaw }}_is_low }" <- ANOTHER TRY
      supersedes:   <- YET ANOTHER TRY
      message: "Below freezing temp of {{ states(genRaw)|float }}"
      reminder_frequency_mins: 60
@tman98 - confirmed. Your YAML has an error, but there’s a bug in the error reporting logic for supersedes.
The issue is that when using a template with supersedes, the template must produce the entire contents of supersedes, not just a part of a dictionary. I’m updating the docs to say:
“When using a template, the value of the supersedes field must be a string that, after template evaluation, cotnains a dictionary (or list of dictionaries) literal.”
# OK
supersedes: "{ 'domain': 'test', 'name': '{{genElem}}_is_low' }"
# Also OK
supersedes: "{{ { 'domain':'test', 'name': genElem + '_is_low' } }}"
# Not yet supported - YAML dictionary mixed with template
supersedes: {  domain : test, name:  '{{ genElem }}_is_low' }
-Josh
Got it thanks - I’ve tried the first example you provided and will report back - I did reload without error though.
I wonder if allowing a template in the pure YAML config style would be a little more legible when using templates. Not urgent.
  supersedes:
      name: "{{ genElem }}_is_low"
Hi Josh,
Is the priority implemented yet, because when I have it in my config, I get an error logged and the generated entities are not created? If I comment out the priority key then it loads without errors.
  - generator_name: garage_freezer
    domain: garage
    name: "freezer_temp_too_high_{{ genElem }}"
    condition: "{{ states('sensor.garage_freezer_temp')|float >= genElem }}"
    generator: [ -18, -15, -12 ]
Generates this log entry -
Err reported: {'domain': 'alert2', 'name': 'error', 'message': 'alerts section of config: not a valid value for dictionary value @ data[\'priority\']. Relevant section: {\'generator_name\': \'garage_freezer\', \'domain\': \'garage\', \'name\': \'freezer_temp_too_high_{{ genElem }}\', \'condition\': "{{ states(\'sensor.garage_freezer_temp\')|float &gt;= genElem }}", \'supersedes\': \'{{ genPrevDomainName }}\', \'generator\': [-18, -15, -12], \'priority\': "{{ [\'low\',\'medium\',\'high\'][genIdx] }}"}'}
Hi @ian_p , Oops, I misspoke. priority does not yet support templates. But it will. I’ll make it so priority templates work in generators.
Josh
Hi All,
I just released Alert2 v1.10.2. Changes:
  • priority when used with generators now takes a template
  • supersedes now can be used with a template on just the domain or name individually.
  • Fixed bug - set context when a trigger fires so that logbook entries report cause of alert state change correctly.
@ian_p , the example using genIdx should now work:
@tman98 , You can now use templates with domain or name individually:
  supersedes:
-Josh
@redstone99 Nice one! Thanks I’ll use that new syntax.
I think there’s some upcoming UI work you’re considering - still lobbying for (at least configurable) not having un-acked alerts disappear if they are beyond the time window as that bit me again last night.
And for supersedes for my usages I’d actually not want to see the prior alert showing in the UI if the superseding alert is on (or maybe hidden behind an expand/collapse concept if you don’t want to lose it entirely?).
And a question on display_msg. Where does that evaluate, server-side or UI side? With Remote Home Assistant I have alert2 entries created on a different instance than where they are displayed so trying to figure out where the template is getting evaluated. For some reason right now they don’t seem to push through to the end UI.
Hi @tman98, I’m not sure how to get display_msg working with remote_homeassistant without changing remote_homeassistant. display_msg is neither a state nor an attribute and so does not get picked up by RH forwarding logic.
display_msg can change value frequently and is not necessarily related to any change in alert status, Making it an attribute would mean a DB write on every update, increasing DB size, and also it would update last_changed, which seems like could obscure interesting changes in actual alert status.
Instead, I use web sockets to communicate display_msg to the Lovelace UI. display_msg is evaluated in the server.
If someone were to change RH, one possibility may be to have it forward along the state_info -> unrecorded_attributes from an entity.
It also occurs to me that priority may also not work with RH for similar reasons, though that may be easier to get working since it doesn’t change as often and is more of a static field.
-Josh
My first try with alert2 and, despite adding friendly name for created alert, the friendly name is not added to the entity, instead an attribute named friendly_name2 was added. As a result, entity does not display friendly name anywhere, and (since entities created by this integration have no unique ID) their actual friendly name (or the icon!) cannot be edited either.
Then i attempted to reload using developer tools as instructed, and everything went to shit.
Too buggy. Hard stop for me.
Bonus gripe: when the notification is sent, the name of the alert is in the text of the notification (rather than it being the title, for example) and this cannot be overridden in any way. WTF.
I really was looking forward to this helping me delete a bunch of binary sensors that were redundant if I have alert conditions. Alas, I was wrong.
clear_notification
Top kek, guys. Top kek.
Hi @Rudd-O , I’m sorry Alert2 didn’t work well for you. Thanks for taking the time to report the problems you ran into. I’m so used to the way it works that getting fresh eyes on it is super valuable.
Can you tell me what happened when you reloaded via developer tools? Reloading shouldn’t make anything worse. It just recreates the Alert2 entities.
Did you try setting annotate_messages to false? If you do that, then you can set done_message to “clear_notification” and the HA companion app shouldn’t get confused. Setting annotate_messages to false prevents Alert2 from inserting the alert name in the message.
It’d be nice if Alert2 somehow warned you if you’re notifying the mobile app and don’t have annotate_message set to false. Maybe I’ll fire alert2.alert2_error once in that case if I can detect it.
Re friendly_name and also unique_ids, I’d coincidentally recently been thinking about getting those working (it’s not trivial). EDIT: Have you tried the Alert2 UI Overview card? friendly_name works for entities displayed there (using the friendly_name2 hack).
If you’re up for it, I’d appreciate your continued feedback!
Josh
Hi All, I’m pleased to release Alert2 and Alert2 UI v1.10.3.
v1.10.3 changes
  • Set unique_id on Alert2 entities. See NOTE below.
  • New UI config options for Alert2 Overview card: title, include_old_unacked, and filter_entity_id.
  • Add list of generated alerts to Alert2 Manager card.
  • Remove friendly_name2 attributed and switch to using HA’s friendly_name attribute (so friendly_name shows up in generic HA entity cards and elsewhere)
  • Switch the more-info entity popup to use the existing more-info framework. (so more-info includes the setting icon now that unique_id is set)
  • Tests & doc updates
@tman98 - Let me know how the config options for the overview card work for you.
@cerebrate - The list of generated alerts in the Manager card should make it easier to see what’s being generated, at least for alerts created via the UI. (was it you who asked for that?)
@Rudd-O - The friendly_name change should make it show up more naturally if you’re not using the Alert2 UI cards.
NOTE - now that Alert2 entities have a unique_id, it is possible that defunct alerts will exist with a state of “unavailable”. This can happen if, for example, your alert config or generator spec changes between HA restarts. If you had an alert that no longer exists when HA restarts, that old alert will still appear with state “unavailable” for short time. To clean up alerts that no longer exist, without inducing unecessary churn in the entity registry, I set Alert2 to wait 10 seconds after HA starts, and then go through the entity registry and purge entries for alerts that should no longer exist according to the config.
I think that should generally work for folks. The one situation I can imagine that might get tricky is if you a) have a generator that takes longer than 10 seconds after HA starts to decide what entities to generate AND b) you tried to modify entity settings (such as “area”) for one of the generated alerts. If this is an issue, we can come up with some smarter logic.
-Josh
Thanks! I’ll check out the UI config options.
Good to know about the implementation and Remote Home Assistant. The implementation using websockets makes sense vs. an attribute. I actually was looking into doing an extension and PR for Remote Home Assistant to support proxy calls for websockets. I may ask for some configurability on the display_msg websocket URL in the UI once I get that done which will realistically be some time.
I feel that priority feels like a first class attribute on the alert. It shouldn’t’ change much and there’s a lot of value in being able to get to it as an attribute via all the standard ways one might access attributes (templates, dashboard tiles, etc.).
@tman98 , not sure if it’s useful, but one mechanism you may want to consider is the state_info and unrecorded_attributes property of the Entity object. Maybe remote HA could pass through those. But perhaps proxying the sockets is a more general approach.
Re priority, I was keeping it out of attributes because priority (at least at present) is a configuration parameter of an alert rather than a piece of dynamic alert state, and attributes didn’t seem the right place to put config info. But I don’t feel super strongly about it.
And yeah, I can change the websocket/HTTP urls if you want.
-J
@redstone99 I don’t think that abstraction of priority really makes sense to the end consumer reading an alert object. To the consumer priority is entirely a state of the alert just like it being on/off, the next snooze time of it, it’s name, it’s friendly_name, etc. There’s nothing special to the consumer and how it was created and implementation shouldn’t be something the consumer has knowledge of. The goal of attributes is to make templating/reading/consumption as straightforward as possible - having to go to websockets for one property (aside from display_msg where implementation details force an abstraction breakage) is forcing the consumer to jump through hoops for an arbitrary implementation detail in my view. It also makes remote home assistant unnecessarily complicated for this one property, so I think it’s a lot better as an attribute.
