Hi everyone,
I am trying to get an Alexa integration via emulated_hue.
Version: Home Assistant Core (version | core-2021.12.8)
Hosting: Unraid - Docker
Network: Ubiquiti - with VLAN (but at the moment with open communication between all VLAN’s)
Hue Emulated Configuration:
host_ip: 192.168.X.X. <-- my Home Assistant IP
listen_port: 80
expose_by_default: false
exposed_domains:
- switch
entities:
switch.on_off_plug_in_unit_3:
hidden: false
I can open the following URLs (Also over the same wireless network which Alexa (Echo) use) :
http://192.168.X.X/description.xml with the result:
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://192.168.X.X:80/</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
<friendlyName>Home Assistant Bridge (192.168.X.X)</friendlyName>
<manufacturer>Royal Philips Electronics</manufacturer>
<manufacturerURL>http://www.philips.com</manufacturerURL>
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>
<modelName>Philips hue bridge 2015</modelName>
<modelNumber>BSB002</modelNumber>
<modelURL>http://www.meethue.com</modelURL>
<serialNumber>001788FFFEXXXXXX</serialNumber>
<UDN>uuid:2f402f80-da50-11e1-XXXX-XXXXXXXX</UDN>
</device>
</root>
http://192.168.XX.XX/api/pi/lights with the result:
{"1": {"state": {"on": false, "reachable": true, "mode": "homeautomation"}, "name": "Weihnachtsstern", "uniqueid": "00:02:65:d0:aa:6a:XX:XX-XX", "manufacturername": "Home Assistant", "swversion": "123", "type": "On/Off light", "productname": "On/Off light", "modelid": "HASS321"}}
To me, it looks like emulated hue is configured correctly.
Unfortunately, when I search for a new Hue gateway or light via Alex, no device is found.
Of course, I used the search before but did not find a solution. Does anyone have an idea or a tip for me?
Cheers,
Danny
