Alexa Contact Sensor not updating status
I installed my own Alex application for HA. Everything is working outside of contact sensors. The sensor shows up, initially shows open/close but after a while it stops updating in Alexa. On the HA side, it works as expected. Just wondering if anyone has ran into this and what is a potential solutions? I’ve disconnected the Alex App/Reconnected and it works for a bit, but then stops again. Any suggestions?
Did you enable proactive events? Amazon Alexa Smart Home Skill - Home Assistant
Thank you, I missed that in the config. That solved it.
