Alexa Custom Skill „Sorry, I’m having troubles right now“
Hey!
I got a couple of tasmota switches connected to HA with mqtt und HA is connected to Alexa with a custom skill and Lambda function.
Proactive events are turned on.
Now Alexa will switch most of the switches fines most of the time, however occasionally she will just say “Sorry, I’m having troubles right/something went wrong“. If I repeat the command it will work again.
This usually occurs after not having called any command for a while but there is no set pattern.
No errors show up in logs of HA, Cloudwatch or on my router, I am kinda running out of ideas right now. As far as I can tell the first command where Alexa responds with the error message doesn’t event reach the lambda function as there is nothing in the logs, neither an acknowledgement nor an error. So far it only seems to happen for the tasmota switches not for Tradfri bulbs I.e.
When I was using the switches with local hue/wemo I never had this issue.
I relinked the skill multiple times and even complete deleted the skill and remade it.
Has anyone an idea what to do?
