Alexa Home Assistant Cloud climate support
Not an issue but much more a question. I’ve successfully configure alexa via Home Assistant Cloud, it works for my temperature sensors (query), switches (on/off) but climate/thermostat are not yet supported.
As some alexa features are gadget, in my opinion this one “Alexa set thermostat temp to …” is really useful. Is there any plan for this ?
Perhaps someone has tried a workaround ? But I’m not finding any “valued” devices in current supported domains. I’ve tried a templated script, but scripts are not supported too.
I replay to myself … climate entities seems to be discovered but I’m unable to get/set temperature (Alexa answer device is not responding). I continue to investigate … perhaps a mistake on my side.
Finally find the issue.
First, my mistake to use the climate component (I’ve build some “virtual” domoticz handled thermostat) but in my current HA version, 0.74.2, the answer when setting the temperature of a thermostat is not working.
Looking at smart_home.py (components/alexa), it seems the context answer is required by Alexa API in the response: https://github.com/alexa/alexa-smarthome/tree/master/sample_messages/ThermostatController.
Without this context as smart_home api answer in this version( https://github.com/home-assistant/home-assistant/blob/dev/homeassistant/components/alexa/smart_home.py#L1444), Alexa set the temperature but report a problem, setting the context (I’ve change smart_home.py source), Alexa answer correctly.
Hi rimram31
Can u please share how did u fix it as i’m having the same issue
I’ve to change the home assistant source code itself, this may depend on you’re version.
The change is in the smart_home.py source, for me it’s installed in /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/alexa folder. Would be good first to save the original in any case, the change is in the response to a “set_target_temp” query, the ha code is missing a “context” (which answer to alexa what has been done).
Around line 1450, change return api_message(request)with:
context={
   'properties': [
              { "namespace": "Alexa.ThermostatController",
                "name": "targetSetpoint",
                "value":
                  { "value": temp,
                    "scale": entity.attributes[CONF_UNIT_OF_MEASUREMENT]
return api_message(request, context = context)
