Alexa Integration Google URL Block
I have put 2 and 2 together and determined that integrating Alexa with HA causes Google to label my URL as deceptive. At first, I thought it was because I was using a Duckdns URL and then a DYNU URL so I registered a domain name to use with a new HA install. I waited a week before adding the Alexa integration. Less than an hour after adding Alexa, Google blocked the URL, and because Firefox uses the Google service the URL got blocked on that browser. It is hit or miss reporting to Google that there is nothing wrong with the URL and even if they unblock they will block again later. The only solution I see at this point is to use the Edge browser. block
I simply report it to them and it stays away for ages …
My URL is still being blocked. Turns out Edge is pretty good.
