I have the same issue as everyone else where I need to reauthenticate the alexa media integration about once a week. I would like to get a notification on my phone when this is needed but I can’t figure out how to trigger this. I can get notifications on my phone without an issue but I can’t figure out what trigger to put into the automation for when the reauthentication happens.
this is the automation I use for that:
- alias: TTS Login Required
- platform: event
event_type: alexa_media_relogin_required
entity_id: input_boolean.tts_alexa_relogin_required
- service: notify.pushbullet_notify
message: 'Alexa Media Player needs re-authenticated'
I created an input_boolean to display on my dashboard turned on by the above as well.
and this shouold clear it:
- alias: TTS Login Success
- platform: event
event_type: alexa_media_relogin_success
- service: input_boolean.turn_off
But I haven’t had to login in quite a while since I switched to using the built-in 2FA code so I’m not 100% sure that method still works.
Do I need the input_boolean?
No, it’s just for a display on my dashboard.
