Alexa, Nabucasa, TTS, etc etc
Hello all!
i have a question related to my HA installation.
I have this equipment:
  • Home Assistant 2022.11.5
  • Amazon Alexa Echo Dot
  • Active subscription with Nabucasa
I use Alexa for light, cover, etc
I would like to use Alexa also for TTS in order to play voice in my automations and so on…
i read a lot but i do not understand what is the best way to use TTS… sometime i read that I have to install HACS, but i do not understand if I have to use it if i do not have an active nabucasa subscription of not…
Could you explain me what is the best way for TTS for my equipment?
thanks a lot
The best way is to use Alexa Media Player. This is a custom component, which means you have to install it manually or through HACS, which is highly recommended.
Not sure if there are other options out there.
thanks a lot for fast feedback.
I installed HACS , did the integration and now TTS works as expected!
thanks!
