yes, the script above does that
No matter what the initial volume is, mine always returns to level 2 after the message.
alias: Test Announcement
description: ""
- platform: state
entity_id:
- automation.office_plug
- service: script.contact_sensor_announcement
alexa_device: media_player.office
alexa_volume: "{{ state_attr('media_player.office', 'volume_level') }}"
alexa_message: "Things go here"
mode: single
Here is the script:
alias: Contact Sensor Announcement
sequence:
- service: media_player.volume_set
entity_id: "{{ alexa_device }}"
volume_level: 0.5
- service: notify.alexa_media
target: "{{ alexa_device }}"
message: "{{ alexa_message }}"
Data: TTS
volume_level: "{{ alexa_volume }}"
enabled: true
Iāve got to be doing something wrong somewhere. Iāve also tried a few other variations that supposedly do the same thing. Those all also return it to level 2 no matter what.
Nope, I would assume this is just a limitation of the input that alexa media player accepts. the value may be dancing on the line between 2 and 3, when being read itās 2, when you provide the value as an input itās 3.
Ah, so it may be at something like .26 but round up or down when setting it back? Thatās lame.
ty.
Yep, pretty much
So I did some more testing and I just donāt think itās saving the current volume each time. If I set the device to volume 8 and then run the automation, it will change it to 5 like the script says, and then when it changes to the āold volumeā, itās 2. So definitely not a rounding error. Iāll just live with it always setting back to 2 and me having to change it manually when I want.
Iāve tested your automation and script with my entities and it is working as expected.
Is your Alexa Media Player integration up-to-date, the current version is 4.7.6. Any version prior to 4.7.4 is likely to have issues getting an accurate value for the volume during the service call for the script.
I think it was the version. I didnāt realize I was on a previous version.
Updated and it seems to be working.
I am using this version and it was working reliable since the alexa media player notification issues (which was solved) and reauth issues popped up:
See next post for script code
Currently alexa media player has issues with reauth, so i have disabled the last step (which waits for the volume to reset as it was before) and made an simple delay. So it doesānt wait forever.
So here is my adapted except with an timeout of 10 seconds. Use the new 4.7.7 Alexa media player released today.
alias: Alexa say something
description: Say something with an Alexa device (tts or announce)
variables:
pause: "{{ 1.7 if type == 'tts' else 0.0 | float }}"
gong: "{{ 1.7 if type == 'announce' else 0.0 | float }}"
reset: "{{ state_attr(target, 'volume_level') | default(0.5, true) | float }}"
dur: "{{ duration | default(7, true) | float }}"
fields:
message:
description: the message (SSML)
example: <amazon:effect name="whispered">Please close the door.</amazon:effect>
required: true
type:
description: tts or announce
example: tts
required: true
description: the target devise as a string
example: media_player.kuche
required: true
volume:
description: the volume of the speach
example: 0.7
required: true
duration:
description: the length of the speach in seconds
example: 3.3
required: true
sequence:
target: "{{ target }}"
message: >-
<break time='{{ pause + 0.2 | float }}s'/> {{ message }} <break
time='1s'/>
type: "{{ type }}"
enabled: true
- delay:
hours: 0
minutes: 0
seconds: "{{ pause | float }}"
milliseconds: 0
enabled: true
volume_level: "{{ volume }}"
entity_id: "{{ target }}"
enabled: true
- delay:
hours: 0
minutes: 0
seconds: "{{ (gong + dur) | float }}"
milliseconds: 0
enabled: true
volume_level: "{{ reset | float }}"
enabled: true
- repeat:
sequence:
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
until:
- condition: template
value_template: >-
{{ (reset | default(1, true) | float) == (state_attr(target,
'volume_level') | default(2, true) | float) or (repeat.index ==
10)}}
enabled: true
mode: queued
max: 5
icon: mdi:bullhorn
to use it:
service: script.alexa_say_something
type: announce
message: "Hallo, das ist ein Test!"
target: media_player.echo_show
volume: 0.35
duration: 4
Works great here
Have fun
pOpY
Thanks a lot, is the script also possible with the type: sequence I am struggling to get it working for example with alexa.weather.play
Do you have any example how i get it working?
The script is made for tts to reset volume afterwards to itās previous value.
I personally donāt use sequences.
Here in the readme you can find Infos: Home Ā· alandtse/alexa_media_player Wiki Ā· GitHub
