AliExpress Solar thermal controllers integration
I’m in the process of making a solar thermal heating system and looking for a solar thermal controller that can output data on home assistant there are many in Ali express did you get any of you had any luck with sr208c sr81q sr1568 sr223 sr609 sr258
And if not is there any branded one that can integrate easily
Otherwise I’m considering starting the journey
Of making my own out of an esp
WT32-ETH01
i have 2 controllers from before i knew better. they are way to expensive for the dumb task they perform.
Mine just monitors temp of roof panel and top and bottom of heatbank and then activates pump based off simple thresholds. I would make my own next time. added advantage will be integration will be simpler.
