i am running ESPHome (2025.6.2) on HA OS (Core 2025.6.3, Supervisor 2025.06.2, OS 15.2) on a Raspberry Pi 3.
I didn’t update my ESPHome devices in a while and also wanted to add some new devices, but for some reason every build keeps failing, no matter which type of board either (ESP8266 and Pico W).
I even tried to do completely barebones configs (as in just the standard stuff, no sensors or anything) and it still keeps failing, usually at api_comonent.cpp:
ESP8266:
INFO ESPHome 2025.6.2
INFO Reading configuration /config/esphome/test-esp8266.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing test-esp8266 (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.3.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.6
Compiling .pioenvs/test-esp8266/src/esphome/components/api/api_connection.cpp.o
xtensa-lx106-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
========================= [FAILED] Took 49.97 seconds =========================
Pico W:
INFO Reading configuration /config/esphome/test-pico.yaml...
Processing test-pico (board: rpipicow; framework: arduino; platform: https://github.com/maxgerhardt/platform-raspberrypi.git#v1.2.0-gcc12)
HARDWARE: RP2040 133MHz, 256KB RAM, 2MB Flash
- framework-arduinopico @ 1.30904.0 (3.9.4)
- tool-picotool-rp2040-earlephilhower @ 5.120300.240818 (12.3.0)
Flash size: 2.00MB
Sketch size: 1.00MB
Filesystem size: 1.00MB
Maximium Sketch size: 1044480 EEPROM start: 0x101ff000 Filesystem start: 0x100ff000 Filesystem end: 0x101ff000
========================= [FAILED] Took 16.73 seconds =========================
As you can see it doesn’t give me any proper error messages either, so i have no idea why this is happening. Any ideas?
