I installed the Fully kiosk integration. Now all the entities are named with “Unknown” for example :inknown battery level (sensor.unknown_battery_level)
unknown current page (sensor.unknown_current_page)
Is this by design and do I have to rename all entities manually or is there another way to give the intities a sensefull name when installing the integration
Maybe removing and re-adding the integration would help.
Already tried that, did not help. Could it have to something with the use of fully kiosk before this integration ?
I’m not sure. I used to use the HACS integration. For a while I had both side by side. I’ve now migrated without issue.
You may just have to rename them one by one.
Open the device under Integrations. There is a pencil at the top right corner to edit the name. After you click Update it will ask to rename the entities also.
