All Fibaro zwave devices broken after 0.95 upgrade
So I upgraded from HA 0.93.x to 0.95.4, and now all my Fibaro devices are either in status “initializing” or “dead”. Before the upgrade, Fibaro devices were working fine.
Anyone an idea what may have caused this, and how to fix it? (tried “heal node”, “heal network”, but no luck)
Other zwave devices like my smoke detector, seem to report correctly.
I have similar problem, not sure exactly at what point of time it appeared, most likely on update from 0.94.4 to 0.95.x. In my case nodes (it is Fibaro Dimmer 2 and Aeon Labs Nano Dimmer) are present and seems to be fully initialized, but I cannot control them from hassio (directly from UI or via automation). Other nodes seem to be OK. In the log file I see timeout error on sending command to node. Strangely their status is reported properly, e.g. if I manually switch device on/off with hardwired button, change of status is properly reported back to hassio. I also tried healing (nodes and network), but to no help. I reverted even back to 0.94.4 hoping this will solve the problem, but not. I’m yet to try complete nodes removals and adding them back again, but since it is linked with significant reconfiguration (due to node name change) I’m dragging my feet here… probably I’ll first try next update to 0.96, when available) and then will troubleshoot more. In meantime I’ve seen quite a few posts about problems with z-wave after upgrade to 0.95.x (nodes not initializing, disappearing, not working properly), so it seems to be a bit broader problem.
Are the developers aware of this? Just wondering if I should open a GitHub issue for this…
