someone experience that issue? I can’t see any history of any entity
Did you delete your database ?
no, I don’t know where that database is
and if so it should have been start the statistics by now
Check the log for database errors.
were I can found the logs?
Developer Tools > Logs. If you see something like “database disk image is malformed” delete home-assistant_v2.db in the same directory as configuration.yaml and then restart home assistant.
thanks, indeed I had that error and deleting the file solved the issue
why this is happened?
Can happen for a number of reasons. The most common as far as I know is after a snapshot restore.
thank you that helped me fixed my issue
- I could not find Developer Tools > Logs.
- I went forward and deleted the home-assistant-v2.db
- After restart I could see history again, but there is no previous history.
Question: can it be restored from a backup?
If it’s not corrupted in your backup, yes.
SQL lite is just a file
It has moved to Configuration / Settings
thank you so much
I have this issue and have no errors in the log? any pointers?
