I’ve installed Home Assistant and added a few dozens of devices using zigbee2mqtt and the SMLight slzb-06m That worked well for several weeks.
This morning, none of the devices were working anymore, they all appeared “unavailable” as if they were all disconnected 7 hours ago.
I then restarted HA (upgrade it to the latest version at the same time), the mosquitto server, the zigbee2mqtt integration, the slab-06m, but it was pretty much the same things (only Matter devices seemed to be ok in the UI).
Then, everything started to work again after a few tens of minutes.
TBH, I don’t what I’ve done that fixed the problem.
Have you already encountered this kind of issue ?
Thanks for your help.
Did you check the Zigbee2MQTT logs ?
I did not check when I add the issue and then I upgrade HA and restarted Zigbee2mqtt. So now it’s too late
Next time, I’ll check the logs right away
Hi, please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
- this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
- this prevents that someone else steps in trying to help
Thanks for giving back to the community!
