Allow Bluetooth USB device to be specified for use with device tracking
Currently I have two USB Bluetooth dongles connected to HA. These are enumerated as hci0 and hci1.
hci0 is long range bluetooth adapter and used to connect to flic buttons around the house. The flic daemon runs separately from HA, and by default uses hci0. This can be overridden.
When HA starts BT device tracking (not LE) it tries to discover devices but throws an error because hci0 is already in use. It then tries hci1 (perhaps default behaviour of the BT stack?) and it succeeds however continues to throw errors in the log, every time it scans.
Is it possible to allow specifying a device in the config, either as hciX or perhaps BT address? If not that, then can the discovery error be supressed?
Log excerpt
17-04-17 12:56:58 ERROR (Thread-4) [homeassistant.components.device_tracker.bluetooth_tracker] Error looking up bluetooth device!
  File "/storage/config/deps/bluetooth/bluez.py", line 31, in discover_devices
    lookup_class=lookup_class, device_id=device_id)
_bluetooth.error: (16, 'Device or resource busy')
  File "/home/andrew/.local/lib/python3.5/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 72, in update_bluetooth
    for dev in discover_devices():
  File "/home/andrew/.local/lib/python3.5/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py", line 38, in discover_devices
    lookup_class=False)
  File "/storage/config/deps/bluetooth/bluez.py", line 34, in discover_devices
    raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
Andrew
I am having the same issues as OP. Please let us choose which USB Bluetooth device we want to track with.
I have been experiencing the same issue recently and opened 2 PRs that should address it - one for home-assistant and one for flicd add-on.
