Allow styling Home Assistant interface itself (not lovelace)
We can style our lovelace dashboards, but can’t style home assistant itself. I would love to be able to apply some basic CSS styling to home assistant – there are some aspects of the UI the persistently annoy me but probably not enough to get them accepted as feature requests. I tried a chrome extension like Stylus, but it doesn’t allow styling the shadow dom at all.
Examples of things I would change:
  • reduce margins and padding in automation editor to make the view much more compact
  • expand the width of some popups when I am on a wide screen
I realize they’d be subject to break if Home Assistant changes things, but offering a simple way to inject our own custom css would be nice.
Only in some limited extent:
  1. You can style SOME lovelace cards in some extent - like “set a color for an icon in Tile card”.
  2. You can set own values for CSS variables in a custom theme. And only SOME variables are officially supported. You may still re-define some “–heading-some-color” variable and it may work NOW, but it may stop working some day w/o a warning. And custom themes are applied both for lovelace & other places of UI.
Based on this, I would say that currently a styling of “not lovelace” parts is more-or-less same as styling of “lovelace” parts.
P.S. Of course we are not talking about card-mod here since this is a custom plugin.
Maybe I’m misunderstanding, but themes allow a lot of customization of lovelace dashboards. As far as I’m aware, there’s no way to apply that (or any) level of customization to the rest of Home Assistant.
Themes allow to define CSS vars which are also used in non-lovelace part of UI.
Simple test: set “primary-text-color” to red.
But there isn’t a way to do anything like this:
  • customize how the entities list view (/config/entities) looks
Right?
Such customization is probably considered as not needed for a majority of users. Others can try using external js (officially supported).
