Alternative to DarkSky
New to HADashboard and cannot sign up for a Darksky - does anyone have a suggestion for an alternative.
Thank you
Maybe AccuWeather?
My Accuweather went unavailable after 115. Tried to delete it to reinstall it from HACS (had custom repository before) and it won’t uninstall. The integration was great while it worked.
AccuWeather Integration has never been officially available on HACS. It was available on GitHub with possibility to install via HACS but only during beta testing. The tests ended a long time ago, so the repository is no longer available. You can use official version in HA, just remove accuweather folder from custom_components folder and restart HA.
Depends where in the world you are as well. Eg Australia has a weather service you can use in HA quite easily
